Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 05-18-2005, 23:31   #1 (permalink)
MisterX GSMFREE's Avatar
Member: 37125
Thanks Meter: 19
Big Problem: Unexpected Exception:BOX_AUTH_ERROR:20
Hello,
a good friend of me has Twister Serial 40XXX with this Problem Unexpected Exception:BOX_AUTH_ERROR:20.
How can we solve the problem ?
Because of this Problem, we would make a Firmware Update from the Twister.
But when we select the REQ.FBI file from the Support Area , the Twister work a little bit and the it shows me that Error: Unexpected Exception:BOX_AUTH_ERROR:00000000
And the 40xxx.req File isn't at the Phoenix directory.
If testet do make the Update with TwisterSuite 1.31 , 1.30 , 1.28 but it didn't work , at every Version are the same Errors .
The Problem comes with the Update from the Twister Suite 1.28 to 1.31.
What can we do ? The Reseller can't help me , because we can't make a 4xxxx.req File .
Is the Twister damaged ?
Thank you
The Following 3 Users Say Thank You to MisterX GSMFREE For This Useful Post:
Old 05-19-2005, 07:48   #2 (permalink)
Member: 739
i don't think it's damage and i think that it can be repaird there is something with the firmware of the box and need to be repair try to see if you can get any from the supports attantion!
Seems like they have fly away on a vacation
Maby Raskal is back try to talk to him thru here.
Br Gsmhq
Old 05-19-2005, 08:53   #3 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
Please contact your RESELLER
Please contact your RESELLER, to send you the FBI files for your twister but you must send the GENERATED file "XXXXXXX.reg" to your reseller
The Following User Says Thank You to RNC_EBM For This Useful Post:
Old 05-19-2005, 08:54   #4 (permalink)
Member: 90865
Originally Posted by MisterX GSMFREE
Hello,
Thank you
Hold on, which versions of TwisterSuite do you have? I think you'll find that you can't go directly from 1.28 to 1.31. I may be wrong on this, but if you use 1.30 it should ask you to update the box firmware the first time you run DCTx, so say yes and then put on the 1.30.001 update and then 1.31.
The error you get is because the box firmware is not matching the program versions.
Note that Sams is broken in 1.31, so before you install 1.31 save the 1.30.001 version of sams.exe and use that instead or you will have problems flashing various phones including A800 and E710 at least.
Hope this advice works and is useful.
Old 05-19-2005, 09:05   #5 (permalink)
Member: 37125
Thanks Meter: 19
@all
After Twister Suite Update from 1.28 to 1.31 shows ous this Error : Unexpected Exception:BOX_AUTH_ERROR:20.
After that:
Then we downgrade the TwisterSuite back to 1.28 , but it shows this Error again .
Then we Upgrade to TwisterSuite 1.30 and TwisterSuite 1.30.001 but it shows this Error again.
Then we Upgrade to TwisterSuite 1.31 but it shows this Error again .
After this all:
We download the REQ.FBI from Twister Support Area , start DCTx 1.3j and made a FIRMWARE UPDATE with this REQ.FBI File.
But this don't work , it shows ous this Error : Unexpected Exception:BOX_AUTH_ERROR:00000000
And there was no File 4XXXX.REQ at the Phoenix directory.
So after that error , we delete the TwisterSuite 1.31 again. And install the TwisterSuite 1.30 again.
Then we started DCTx again , made FIRMWARE UPDATE with the REQ.FBI File.
But it doesn't work , the same Error like on TwisterSuite 1.31 (Unexpected Exception:BOX_AUTH_ERROR:00000000)
And no 4xxxx.REQ at the Phoenix Directory.
Thats the Problem
Old 05-19-2005, 09:11   #6 (permalink)
Member: 739
as i said the firmware inside the box is damage as i see it i think it is corrupted, i think your reseller need to have a big look on it maby send it to twister to fix it.
but i can't say this really becuase i am not 100% good on this with firmware and stuff but it seems like the firmware inside the box is corrupted or something!
Br Gsmhq
Old 05-19-2005, 10:08   #7 (permalink)
Member: 18966
Thanks Meter: 59
same problem with ufs3 gold after upgrade to dctx1.3h it work for 2 day after that it do same pb with me and i do same procedure but no success now i am waiting answer from ufx office but my problem is from where i bought the box he is not the resseller anymore there is another one.
Old 05-19-2005, 13:15   #8 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
@MisterX GSMFREE
Try this:-
Uninstall TwisterSuite AND USB Driver
Make sure all folders have gone, if note delete them e.g.
\Program Files\Nokia\Phoenix
\Program Files\SarasSoft\Twister
Install Suite 1.28 and use the USB driver from this install:-
\Program Files\SarasSoft\Twister\USB Driver
Run DCTx ignore any messages and try to update the firmware with req.fbi, if a xxxxxx.req is not generated, try to update firmware with an old xxxxxx.fbi and then use req.fbi
I think you must get twister working at 1.28 before upgrading, let me know how to get on.
Odia.
Old 05-19-2005, 16:35   #9 (permalink)
Member: 37125
Thanks Meter: 19
But i have no old xxxxx.fbi file .
Old 05-19-2005, 21:18   #10 (permalink)
Member: 4042
Does this mean you have tried what I suggested and a xxxxxx.req did not get generated?
Odia.
Old 05-20-2005, 06:57   #11 (permalink)
Member: 37125
Thanks Meter: 19
Yeah , this does it mean .
Old 05-20-2005, 14:06   #12 (permalink)
Member: 4042
Then I think the best solution, is for you to return the box to the reseller for exchange or repair.
Odia.
Old 09-02-2007, 20:55   #13 (permalink)
Member: 299723
Thanks Meter: 7
the same problem with me
i am sure there is problem with my box firmware
but how to fix no one knows my reseller says i cannot do coz they just know selling theyr not serious fixing problems
this is mean attitude
The Following User Says Thank You to mizhar_khan For This Useful Post:
Old 02-03-2009, 17:19   #14 (permalink)
Member: 555789
This seems all to be bull--we run 3 boxes and each one went out of order with that box_auth_error.believe this is big set up from producersside (or whoever is responsible
for that ****)---they are again trying to suck money from us---like all other flasherbox vampires!!!!
The Following User Says Thank You to maurice11 For This Useful Post:
Old 02-05-2009, 16:47   #15 (permalink)
Member: 756490
After that:
After this all:
unexpected exception:BOX_AUTH_ERROR:20 bannu HWK 23 12-23-2008 20:46
Page generated in 0.25323 seconds with 10 queries
