07-30-2005, 20:52 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: EGYPT Age: 42
Member: 11571 Status: Offline Thanks Meter: 24 | to support stupid move from me after this box give me ( unexpected exception:box_auth_error:32 ) |
07-30-2005, 21:21 | #3 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: UK
Member: 90865 Status: Offline Thanks Meter: 1 | Quote:
You'll have to ask your reseller to send you back the needed firmware file. -- WolfMan | |
07-31-2005, 02:19 | #5 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Manila, Philippines Age: 41
Member: 137104 Status: Offline Thanks Meter: 8 | Quote:
now you need to send to your reseller to get your "fbi file" now your box is totally damage without the fbi Regards | |
07-31-2005, 12:42 | #7 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Cebu, Philippines
Member: 15652 Status: Offline Thanks Meter: 344 | There is a certain release (i dont know what version) of twister suite that can be sucessfully upload the fbi file. Quote:
07-31-2005, 12:44 | #8 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Quote:
Hi tata Everytime you make A request for a "req.fbi" this changes the expected reply "XXXXX.fbi" for your Twister from your Supplier. 1.You Must now Generate req.fbi again and send to your reseller. 2. Do not run twister again until your supplier send you file back "xxxxx.fbi" to upload to your Twister.(xxxxx is your box Number). 3. When you receive xxxxxx.fbi from your reseller Using DCTx 1.3a Connect to Twister Click on UFSx Tab Click on Update Firmware upload the attached fbi to your box Re-Connect and enter the new activation keys as below, enter the DCTx one last, this will allow you to activate all the modules from just DCTx. MoAc: xxxxxxxxxxxxxxxxxxxxx Siem: xxxxxxxxxxxxxxxxxxxxx EriN: xxxxxxxxxxxxxxxxxxxxx DctN: xxxxxxxxxxxxxxxxxxxxx SamN: xxxxxxxxxxxxxxxxxxxxx XXXXXXXXXXXXX will be new keys from your supplier sent with req.fbi If you run Twister "xxxxxx.fbi" again before your reseller sends you "req.fbi" then the number that you sent to your reseller is useless and you have to start all over again. I did same as you last year by accident and this is what Odia told me to do Regards Charlie Last edited by Charly; 07-31-2005 at 13:23. | |
07-31-2005, 12:59 | #10 (permalink) | |
Hi Tata WARNING: DO NOT DO THIS UPDATE IF YOUR BOX IS WORKING ! ! ! ! ! If you box NEEDS this update then the software will show you a BOX_AUTH_ERROR_xx If you do NOT HAVE THIS ERROR the DO NOT update your box ! ! ! After you start the update your box will not work until after you complete the update. ASK YOU RESELLER for the REQ-FBI exchange. This can take 1 - 48 hours ! ! Dear Twister Users: Please do the following Procedure in order to upgrade your Twister boxes: 1. Download the New Firmware\req.fbi from support area 2. Install latest Twister suite 1.13 3. Open the Twister_DCTx.exe 4. Press Update Firmware - select the file req.fbi 5. Wait until the process finish 6. Go to Directory: C:\Program Files\Nokia\Phoenix and find the file name 2xxx.req 7. Send this xxxx.req to your reseller and you will get your xxxx.fbi file back to upgade new firmware again. 8. Now your box is ready to using with lastest version of Twister software. Regards Charlie | |
07-31-2005, 13:14 | #13 (permalink) | |
Hi Tata yes 100% you need to run above req.fbi then send to your reseller who will have to go to Sara's for new calculation and then your reseller will send you back new code to re-start your box. All will be Okay then. Very dangerous button UPDATE FIRMWARE in dctx platform | |
07-31-2005, 13:26 | #15 (permalink) |
Member: 2008 Status: Offline Thanks Meter: 4 | Hi tata If you need the req.fbi it can be found in the support area in the New Firmware Directory. Regards Charlie If you cannot find/download let me know and I will post it to you. I too was asleep when I did it last year. |
KP105 no support all sim from me | djibrilcoulibal | Infinity-Box | 10 | 01-23-2010 23:45 |
when are you going to support lg cu515 from att | denisirias | VygisToolbox | 5 | 01-25-2008 01:27 |
Can you add to support G600AAGH1 frmware from Tmobile ???? | wgmmmx | UST Pro II | 5 | 11-23-2007 22:35 |
CAn you add to support G600AAGH1 firmware from Tmobile ?? | wgmmmx | NSPRO | 0 | 11-22-2007 12:18 |
