twister HWK error pls pls pls need your help gud day to all sir and master and co member asking your help pls....im newly HWK user and i buy my HWK this february 16, 2011.....with cd software HWK support suite exe. and HWK suite setup exe.......before i install this softawre......i have previous setup installed in my computer this one ufs suite_setup_v03.03.000 i forgot to uninstall...i accidentally run the HWK support suite exe. and successfully installed and i run the HWK update and successfully update too........and then i run the HWK suite_setup exe and there is error found..........so i decided to uninstall all set up the previous ufs suite_setup_v03.03.000 and HWK support suite exe. and HWK suite_setup.....because when i read the correct procedure i do mistake coz i did not uninstall the ufs suite_setup_v03.03.000.........so now almost six days i cannot update my HWK coz there is error found heres the logs error...pls help me sir , master and co member please please please........pgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:2/21/2011 4:50:04 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : xxxxxx -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-xxxxxxxxxxxxxxxx -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. |
we have the same error i cant figure it out |
Return your HWK to your reseler. |
I know you work dedicate on HWK , But B4 replying a post necessary to read & check every thing in detail . How you advice it ? Quote:
@ zumaric Use latest update client V2.2.0.0 |
Mr.aayushjaiswal not solve the problem by raskal.exe first u try then post it |
B.R |
Hi aayushjaiswal very very thx my box problem is solve |
Any body help me my iphone 3gs write firmware 4.3.5 then gone to recovery mode any solution step by step |
From six day I am trying to update, but Worthless..... Actually, this is my Clint HWK. I am trying to update it from last 6 days. Always same Problem as follows:- Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:9/10/2011 9:55:08 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 82999 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID : A1.04-PRO1-**************** -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. I want to check this HWK, is this BLOCK from Server? if Yes, Reason, please? |
uninstall all saras then clean up registry restart and install support suite try upgrade |
Reinstall all then install latest support suite ............... |
