11-09-2004, 05:56 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: australia Age: 47
Member: 18782 Status: Offline Thanks Meter: 11 | Sonyericsson t610 can anyone plese tell me what is the deal with the new sonyericsson t610. i unlock one t610 and it is dead. can anyone please give a step by step how to unlock the new sonyericsson. 1. how to find out if the phone is new 2. where can i find the mcu file 3.how to find out what version the phone is please anyone i need your help |
11-09-2004, 12:00 | #2 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | Carefully look below, and do as it is, your phone will be unlock successfully! Works 100% on any T610. already tested with twister. Step1: Remove "Protect SA then Flashing GDFS" the click, Choose the GDFS File Press" GO " Button (After flashing the GDFS the IMEI will be changed) Step2: Disconnect the phone , and connect again Press"GO" After Boot phone, Press "RESTORE SA" Now you will be in backup folder Choose the last backup file with IMEI same as the phone software IMEI (*#06#) this file is backup file after GDFS Flashed to phone. Now flash the phone. Step3: Disconnect the phone, and connect again Press"GO" , to boot the phone, Press"Init SecBlk", Now coming "IMEI Restore", if the IMEI is not the same as phone then you can change it to original imei here Press"OK" Voila!!!!! you have a T610 Unlocked! |
11-09-2004, 16:05 | #3 (permalink) |
Member: 18782 Status: Offline Thanks Meter: 11 | thanks for the reply but how do you do the rsa, cuz i did one and after connecting the phone and i push rsa buttom, after it want a mcu file i don't have any mcu file in me computer. where can i find a mcu file for the phone? |
11-09-2004, 16:26 | #4 (permalink) |
Member: 18782 Status: Offline Thanks Meter: 11 | on the twister support area. there is step by step for unlocking the new t610. 1) Check the software version in the phone 2) Select the MCU file for that model (must match the phone version) 3) Select RSA Flash Recovery ON 4) Press the RSA button 5) After booting up then do your usual procedures my question is how do you check the phone version? and what is MCU file where can i find it in the support area? are the file in the flashfile icon in the twister support area? thanks please help |
11-09-2004, 16:32 | #5 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16927 Status: Offline Thanks Meter: 134 | No No No...!! Arc: this instruction is very difficulty ) Shockboy: DIV Terminator instruction: 1. go there for flashes T610: http://www.gorden.de/download/members.htm and download what you need flash 2. Check version in phone (> * < < * < * = right joystick * left left * left * ) 3. Select model of SE in DIV_LPT5. 4. If R6xxxxx then in DIV_LPT5 go to RSA , click Remove RSA and Do Job, after done you must flash AVR MCU. 5. In Div_LPT5 goto FLASH click on AVR MCU two times and select flash file (example: T610_EMEA1_R4C003_e.sbn) and click Do Jobs. 6. After flashing (~5-6min) disconnect and connect phone. 7. Goto in DIV_LPT5 Unlock click Readl All Codes and Unlock Phone and click Do Jobs Twister instruction: 1. Go to support section, download (SE\Flashfile\T610\) files t610_125572_r4c003_emea1.bis or t610_125572_R6C005_emea1_rsa_off.bis or etc. 2. Switch on Twister_RTP, select model (T610) click RSA buttom. 3. After done, disconnect and connect again phone. 4. Click Go button, after connected on right side select MCU file (you download it in step 1) 5. Then click on the top of window button Flash MCU 6. After done disconnect phone and switch ON. 7. If you want unlock, connect switched off phone. 8. You must download from support T610_gdfs_big and flash GDFS. 9. After done, click InitLocks. Vuala ) br. fingusio |
11-09-2004, 20:08 | #6 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | my solution is to unlock new T610 with twister but yours is: 7. If you want unlock, connect switched off phone. 8. You must download from support T610_gdfs_big and flash GDFS. 9. After done, click InitLocks. maybe this works for you,i don't think so, and i didn't test it. should see feedback here. |
11-09-2004, 20:10 | #7 (permalink) | |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | Quote:
get MCU and MOD and GDFS file from twister support, man. | |
05-26-2009, 18:39 | #10 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 408 | Quote:
how to up date sonyericsson T610==>SE T610 | mobile-hardware | Sony Ericsson | 3 | 11-03-2003 17:45 |
Sonyericsson T610 And Other Models Online Server !!! | bahtiyar | Main Sales Section | 0 | 07-02-2003 20:12 |
simemu6.0 is not working on SonyEricsson t610? | deepdark | Sim Cloning and Scaning | 5 | 07-01-2003 23:09 |
SonyEricsson T610 - Motorola A760 - WANTED!!! | VsH-GsM | Wanted Products | 0 | 03-07-2003 20:20 |
New SonyEricsson t610 t310 | bonzo | Sony Ericsson | 0 | 03-04-2003 22:02 |
