12-05-2004, 22:57 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Age: 44
Member: 95864 Status: Offline Thanks Meter: 0 | Twister power surge on hub port |
12-05-2004, 23:52 | #3 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
How will Service Pack 2 affect the voltage being drawn on a USB line? What have USB2 drivers got to do with it? @LMing Do you have any other devices plugged into your USBs ports at all, or just Twister? If you have tried it on a different PC, was that PC a totally different sort (ie different motherboard) or the same? It's possible you have too many devices plugged in already, which will cause the problem you've got, your USB ports aren't able to generate enough voltage or there might be a problem with your Twister box. If you're able to get your hands on a powered USB hub (they're usually pretty cheap) then try plugging your Twister into that, it might help. Otherwise if you keep getting the problem I would return the unit to your reseller. | |
12-06-2004, 01:17 | #4 (permalink) |
Member: 95864 Status: Offline Thanks Meter: 0 | Thank you for your reply, to muppet, first I thought I had too many usb devices on my computer, then I tried on 2 laptop, 1 desktop, it all happen the samething. therefore I am very confused about it since twister suite did dectect my twister. thank you for your time |
12-06-2004, 02:22 | #5 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | Well, I don't know the hardware of the Twister Box very well, but in all my use of it I've never encountered this problem. I suspect that you might have a faulty Twister Box. Contact your reseller and tell them about the problems you've had, they should be happy to replace it (or at least test it for you) |
12-06-2004, 08:47 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | The problem LMing is mentioning is when you use twister and also the port available in twister !!! or if you use USB hub without external power !! no software or twister problem !! thats all, i have same problem only and only because of these two reasons and solved by using only twister and all other devices pluged out !! |
12-06-2004, 14:36 | #8 (permalink) |
Member: 95864 Status: Offline Thanks Meter: 0 | Hi thanks for the reply, I treid on different computer, same thing still, it seems it's a device inside the twister since twister is also an USB hub by itself, here is the pic |
12-06-2004, 15:08 | #9 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | i get this problem all the time with my box to, it only started to happen after i cut the tracks on the twister pcb so as i did have to use the little yellow gender changer |
12-06-2004, 17:47 | #10 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | @LMing, Do you only get this issue when you plug a cable into the box or all the time? From looking at your USB output it looks like a Twister internal hub failure. Odia. |
12-07-2004, 07:51 | #13 (permalink) |
Junior Member Join Date: Oct 2002 Age: 48
Member: 16328 Status: Offline Thanks Meter: 0 | I also experienced this thing before on some boxes that i sold, maybe twister should look on this, I notice the problem comes when the box is using smd type cpu's and not the ordinary dip ic's, but this is only my observation, maybe you should look which ic you have and if its the smd type then perhaps im right. BR Ed |
Power surge on hub port | youtel | iPhone 4 / iPhone 4S | 9 | 07-23-2010 18:22 |
EUB Power Surge on Hub Port?how to solv | rana4star | Easy-Unlocker | 3 | 09-30-2008 02:49 |
Dead 903SH Won't TURN ON...Power surge from outlet | supergk01 | Sharp | 0 | 09-13-2007 10:11 |
NSPRO Power Surge Cable is Available !! | UnlockCellular | NSPRO | 14 | 04-30-2007 14:46 |
Z400 and USB Power Surge | drancill | UST Pro II | 4 | 01-18-2007 04:47 |
