04-26-2005, 21:59 | #1 (permalink) |
Crazy Poster Join Date: Nov 2003 Location: Lancs
Member: 43724 Status: Offline Thanks Meter: 1 | Twister will not flash dead Nokias The phones are 2x 6230 & 2x 7610. Any help greatly appreciated |
04-26-2005, 22:03 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | try connecting a charge to them so that they are getting power, then connect with charger still connected and try that. ive found this has helped me out many times |
04-26-2005, 22:10 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | Or manually select model and flash files, then click Flash.. you should be able to force it to flash without autodetection. Which model is causing the problem? |
04-26-2005, 22:14 | #4 (permalink) | |
Member: 43724 Status: Offline Thanks Meter: 1 | Quote:
04-27-2005, 01:20 | #5 (permalink) |
Freak Poster Join Date: May 2004
Member: 64341 Status: Offline Thanks Meter: 1 | do full installation again. u need to explain better. sometimes twister will not flash when it hangs on erasing. if this is what u are talking about then wash the phone with tinner . hope u know what thaat is ? if u do not then go to a paint shop ask for it pay and use it .it will work |
04-27-2005, 20:22 | #7 (permalink) |
Member: 43724 Status: Offline Thanks Meter: 1 | Getting the following error when I try to flash the 6230 1st Boot Err: Bad Resp UPP, 03 FF FF 72 Rebooting Mobile I have also noticed that the yellow PWR light goes off when any of the dead phones is connected |
04-28-2005, 04:33 | #8 (permalink) |
Freak Poster Join Date: Apr 2004
Member: 62111 Status: Offline Thanks Meter: 0 | Not sure if this will help in your case, but I have also posted a flashing problem with 6230 & 7610. However, I solved the 6230 flashing when I used a working cable borrowed from a friend. It turned out to be cable problem in the case of the 6230. The cable I borrowed was from Griffin flasher. As for the 7610, not solved yet, but I suspect it could be hardware problem as Twister is able to detect phone, but could only erase 1-2% of the flash. Could be a bad flash chip. WBR |
05-17-2005, 10:46 | #12 (permalink) |
Junior Member Join Date: Mar 2005 Location: Port Harcourt, Rivers State, Nigeria. Age: 41
Member: 129106 Status: Offline Thanks Meter: 0 | I just got a 7610 with no power... I downloaded a flash file forl the support site but whenever I tyr to upload this file.. an error message always occur. I tried a second flas file after download but another error also occurred similar to the first. The first error was CH-12 not found while the second was EMEA 14.0 ot detected. Plz could any body help me with this problem !>? |
W550 Will Not Flash | afrodizzy | Cruiser Suite | 1 | 09-08-2006 14:26 |
Twister do not flash 3220-6230-7260 | market_3b2002 | Twisterflasher | 8 | 06-26-2006 12:59 |
X70 will not flash! (not killed by flashing) | AlexG | Panasonic | 3 | 07-04-2005 07:57 |
P900 Bluetooth Module Will Not Flash | muppet | Cruiser Suite | 2 | 01-11-2005 05:22 |
SE T610 ,twister can not flash mcu and gdsf! | mobx montenegro | Sony Ericsson | 0 | 10-11-2004 00:38 |
