Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member ![]() Join Date: Dec 2003 Age: 35
Member: 47220 Status: Offline Thanks: 0
| Unlock KG800 without hwk module? can u confirm? UPDATED Please can anyone confirm that its possible to use TWISTER (original) with UFS 3.01 OR 3.02 obviously patched with HWKKiller21b without a hwk module to unlock KG800? i know it works with all others as i have tested for example UFS_SAM with E900 works fine but not with LG_GSM! i have tried everything but just doesnt do anything when i press boot! I even tried doing that pin trick and it does say it has found hwk but still doesnt boot up. please if u can help get in touch! mazzotony@hotmail.com Last edited by tonybigger; 02-19-2007 at 20:32. |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2005 Location: Planet Earth :d Age: 37
Member: 133099 Status: Offline Thanks: 36
| Yes... KG800 tested with HWK crack version 3.01 .... Unlocked successfully Press Boot and then put cable inside and wait to boot the phone .... that's it... |
| | #3 (permalink) |
| ye? u sure u havent got a hwk module or clone inside your twister?? i have tried everything on 2 different pc's doesnt do anything when u press boot!! what did u use? im not exactly new to the unlocking scene i have tried al sorts! i downloaded everything and read every single thread and yet people claim that it works. What firmware do you have in your twister? can u give me a link to where i can download 3.01 so called cracked and working 10000%%%%? at some stage i had that problem that someone posted that turns your box into usb > serial and repaired with ufs diag that lucky enough saved it! please please help explaining step by step what i need to use on a fresh pc..... thanks. Last edited by tonybigger; 02-19-2007 at 11:28. |
| | #4 (permalink) |
| anybody else had same problem?? I have heard that many have had same problem and im wondering if they managed to get it working in the end or if the just gave up and went out to buy a HWK....... im writing all this to help people and myself understand, as i have spent 2 days solid learning. Im a smartmoto (i uploaded new testpoints to smatmoto) and cruiser man so i had plenty to learn with twister!! My conclusions: version 3.0 works fine patched with HWKkiller 2.1b even LG_GSM (even if it doesnt do KG800 choosing any other model after pressing boot it will show booting... at bottom of screen also tried on 1 fone) if not patched with HWKkiller.Without HWKkiller but with wires shorted after using rask2 it will say "RASK FIRMWARE DETECTED".To come back from this problem just use UFS3tools (be carefull what version u use as 1 contains hwk emu button instead of fix and update button that transforms SARASBOX in usb>com problem described below) check write firmware box and click on Fix and Update. If u restore file given from amir called AmirSkillz99318 after u have fixed and update firmware then u try again any UFS app it will ask for activation string and even if u calculate and ente it will ask for it again, again and again.SO IN THIS CASE TO USE CORRECTLY ALL UFS SUITE U NEED TO DO NO MODIFICATIONS TO YOUR TWISTER SIMPLY PATCH WITH HWKkiller 2.1b. version 3.1 works fine patched with HWKkiller 2.1b no pins shorted for all other sections as i said tested with UFS_SAM and UFS_BB5 but not LG_GSM (fone doesnt boot up not even manually just turns on as usual) as soon as u press boot, the lights on twister box flash but does nothing with and without pins shorted. version 3.3 works same as 3.1 but yet again not working with LG_GSM using any driver. For those that dont know be very carefull using HWKkiller 2.1b on this version as it deletes vital files to boot your pc (to solve this problem i took my hard drive out of my laptop and with adaptor to ide i installed in my home pc as slave i booted normally and copied files into root of laptop hd) so make sure u use SBM (SARAS BAD MOVE) after installing the patch! For people that after trying and trying have turned their box into a usb>serial, allow windows to connect to internet to search for drive hopefully it will find it or at least for the first tim in my life it did for me. then after u install the driver simply connect with UFS_Diag and restore your serial number after that it will tell u to disconnect and reconnect. after this close program disconnect twister from pc an reconect and voila!! it back to normal again. And this procedure below is only if u have a clone HWK even if not specified below. Step 1 can help many people save their UFS devices as it restores firmware back to original 2.6 with shorted pins says HWK found but no hid and without obviously just gives u twister box. As for step 2 where it says "restore with file i give", u cant do that if u have shorted pins 17 to 19 it says error programming or something similar. u can only do that step after u have rask2 only then it will change HWK hid to a trial. And even in that case u still cant use with LG_GSM for KG800!! What U Need Got one UFS or Twister box...UFS Tools...HWK Tool...Raskz 2...and A file I am Providing.... 1..First Do the PIN trick as u Know Its posted Many Times 2..Now Run UFS tools and Just Check Firmware and click "FIx and Update"After Dont done Done Disconnect Box and CLick on Restore and Give it the FIle I am Providing now When its Done Remove BOX 3..Now Raskz 2 and Write It 4...Now Run HWKTOOLS by Raskal And u will Get its All Update Done Easily with out Error Even on PIN short Trick...On Prefered HID leave it on Default and CLick "Start Update" SO its DONE.. 5...Now u can Use All DCTX 1.4 D (with Imei Patch Option Working) and LG GSM SAM...If ask for String Calculate it with UFScode (uknow) ****What IS DOne all this Will Change ur HWK HID and Thats ALL**** Now if anyone can prove me wrong providing 2 screenshots of first main screen after u press connect so i can actually see if u have a HWK in your box or if u did actually use HWKkiller patch and second where i can see saying below booting!! thanks to all!! Last edited by tonybigger; 02-20-2007 at 22:35. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Can We Unlock Kg800 With Usb Cable On Hwk | irfan99 | HWK | 1 | 12-26-2006 18:16 |
| can anybody confirm if z105 can be unlock by choosing x430 in ust | ashvin | QUALCOMM Models (3G) | 2 | 08-06-2005 20:55 |
| can anybody confirm if z105 can be unlock by choosing x430 in ust | ashvin | QUALCOMM Models (3G) | 2 | 08-06-2005 15:36 |
| Can anyone Confirm Uni 2.21 beta unlock V220 | cellunlock.com | UniMoto | 7 | 08-15-2004 21:49 |
