11-08-2004, 15:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16927 Status: Offline Thanks Meter: 134 | bug in 1.27 ? SE T610 can't unlock Today i have 4x T610 from O2 to unlock and change language. Phone have R60005 version, i click RSA, RSA removed, flash it and all OK. But when I click InitLocks all been OK but phone dosent Unlocked:< Blk_0 : 800000 IMEI : 353989-00-317379-3 ULock : Factory_Off : 0000 NCK : 82110220 NSCK : 70985399 CCK : 80152156 SPCK : 59993314 LockSt: Sim_Locks Open, Mcc+Mnc: 262-07, AAAA AA Mcu_Sw: R4C003 prgCXC125572_EMEA_1 **************************************** GDFS Flash Erased: 1 sector(s), Time: 00:00 * GDFS Flash Written: 49152 byte(s), Time: 00:01 * <--- click InitLocks Locks Init Done, Time: 00:03 * **************************************** Blk_0 : 800000 IMEI : 353989-00-317379-3 ULock : Factory_Off : 0000 NCK : 82110220 NSCK : 70985399 <--- then clik Info again CCK : 80152156 SPCK : 59993314 LockSt: Sim_Locks Open, Mcc+Mnc: 262-07, AAAA AA <--- dont unlocked Mcu_Sw: R4C003 prgCXC125572_EMEA_1 **************************************** I unlock this phone by Terminator without any problems. I call to my resseler (Multi-Com) and he told it maybe some Bug? He dont test unlock on TwisterSuite 1.27 this type phone. Any solution? Anybody have this problem before? best regards from Poland fingusio |
11-08-2004, 18:56 | #4 (permalink) |
No Life Poster Join Date: Aug 2002 Age: 57
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | Hi, I've just done a T610 R6C RSA-unlock with 127. Perfect. Mcu_Id: 5B 08 02 01 FF FF FF FF Certificate Accepted Prologue Ok PayLoader Ok Certificated Boot Ok, Time: 0:04 IMEI : XXXXXX-XX-XXXXXX-X Ram_Ld: 031003 1530 EANCXC1327525_R1A Fla_Ld: WAKCXC1327507_FLASH_LOADER_B R1A RSA Flags Removed Mcu_Id: 5B 08 02 01 FF FF FF FF Secure Boot Ok, Time: 0:23 Fl_Id : 00898864 Intel 28F640W18T {2} Blk_0 : AD0000 IMEI : XXXXXX-XX-XXXXXX-X ULock : User_Off : 0000 ***** : "New" GDFS SA Layout, Cannot Calculate Codes LockSt: Sim_Locks Closed, Mcc+Mnc: 216-70, 5555 55 Mcu_Sw: R6C005 prgCXC125598_EU_7 BackUp:'T610_XXXXXXXXXXXXXXX_lck_uns_2004_11_08__1 8_26_32.sim' MCU Flash Erased: 1 sector(s), Time: 0:01 MCU Flash Written: 65536 byte(s), Time: 0:01 MCU Flashing Done, Time: 0:03 Flash Recovery Done Using: t610_125598_R6C005_eu7_rsa_on.bis GDFS Flash Erased: 1 sector(s), Time: 0:00 GDFS Flash Written: 28672 byte(s), Time: 0:00 Locks Init Done, Time: 0:05 User Break, Total Time: 1:22 Mcu_Id: 5B 08 02 01 FF FF FF FF Certificate Accepted Prologue Ok PayLoader Ok Certificated Boot Ok, Time: 0:04 IMEI : XXXXXX_XX_XXXXXX_X Ram_Ld: 031003 1530 EANCXC1327525_R1A Fla_Ld: WAKCXC1327507_FLASH_LOADER_B R1A RSA Flags Removed Mcu_Id: 5B 08 02 01 FF FF FF FF Secure Boot Ok, Time: 0:52 Fl_Id : 00898864 Intel 28F640W18T {2} Blk_0 : AD0000 IMEI : XXXXXX-XX-XXXXXX-X ULock : Factory_Off : 0000 ***** : "New" GDFS SA Layout, Cannot Calculate Codes LockSt: Sim_Locks Open, Mcc+Mnc: 216-70, 5555 55 Mcu_Sw: R6C005 prgCXC125598_EU_7 BackUp:'T610_XXXXXXXXXXXXXXX_uns_2004_11_08__18_28 _42.sim' MCU Flash Erased: 1 sector(s), Time: 0:01 MCU Flash Written: 65536 byte(s), Time: 0:01 MCU Flashing Done, Time: 0:03 Flash Recovery Done Using: t610_125598_R6C005_eu7_rsa_on.bis User Break, Total Time: 1:12 BR Roy |
11-08-2004, 19:31 | #5 (permalink) |
Member: 16927 Status: Offline Thanks Meter: 134 | hmmm, I dont understand. First you have: ***** : "New" GDFS SA Layout, Cannot Calculate Codes LockSt: Sim_Locks Closed, Mcc+Mnc: 216-70, 5555 55 Mcu_Sw: R6C005 prgCXC125598_EU_7 and in second part you have again: ***** : "New" GDFS SA Layout, Cannot Calculate Codes LockSt: Sim_Locks Open, Mcc+Mnc: 216-70, 5555 55 Mcu_Sw: R6C005 prgCXC125598_EU_7 Mcc+Mnc: 216-70 is still the same... and phone have simlock or I bad think....?? br. fingusio |
11-08-2004, 20:55 | #7 (permalink) |
Member: 16927 Status: Offline Thanks Meter: 134 | hmm strange:< i click InitLocks and Info again and mcu+mnc are still locked:/ and when I put other sim card then i see on phone "please insert correctly sim card" any other solution ?? br. fingusio |
11-08-2004, 21:19 | #8 (permalink) |
Junior Member Join Date: Oct 2004 Location: CA USA Age: 55
Member: 88109 Status: Offline Thanks Meter: 0 | Why You Don't Read The Old Posts,mate??? Are You Know How Many Posts Were About This??? 1.flash "gdfs"(uncheck "protect Sa When Flashing Gdfs") 2.press "init Secblk"(restore You Original Imei) That's All |
11-08-2004, 21:22 | #9 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Odia. | |
11-09-2004, 12:03 | #11 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | Carefully look below, and do as it is, your phone will be unlock successfully! Works 100% on any T610. already tested with twister. Step1: Remove "Protect SA then Flashing GDFS" the click, Choose the GDFS File Press" GO " Button (After flashing the GDFS the IMEI will be changed) Step2: Disconnect the phone , and connect again Press"GO" After Boot phone, Press "RESTORE SA" Now you will be in backup folder Choose the last backup file with IMEI same as the phone software IMEI (*#06#) this file is backup file after GDFS Flashed to phone. Now flash the phone. Step3: Disconnect the phone, and connect again Press"GO" , to boot the phone, Press"Init SecBlk", Now coming "IMEI Restore", if the IMEI is not the same as phone then you can change it to original imei here Press"OK" Voila!!!!! you have a T610 Unlocked! |
11-10-2004, 00:25 | #12 (permalink) | |
Member: 88109 Status: Offline Thanks Meter: 0 | Quote:
11-10-2004, 01:56 | #13 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Egypt Age: 46
Member: 4263 Status: Offline Sonork: 100.1582330 Thanks Meter: 49 | really unlocking SE with twister is compicated really i use twister for flashing SE but for unlocking i use terminator manytimes after i flash GDFS and do initsec mobile not power until i rebuild imei using terminator hope saras make unlocking se like terminator coz he was the master on ericsson before. |
11-10-2004, 10:01 | #14 (permalink) |
No Life Poster Join Date: Nov 2003 Age: 39
Member: 44610 Status: Offline Thanks Meter: 50 | hehe... Funny enough his lock codes generated are the same with mine 82110220.. So strange, i guess diff imei. BTW.. For me i dont remove RSA... Just open fone and use the old method (TP) and get it unlocked and give back to customer.. Very Easy Br |
BUG in New Ver 3.3 can't unlock Nokia on it | hasnain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-21-2009 11:46 |
BUG in new cruiser 13.21 !! Can't fix P910 !! | wgmmmx | Cruiser Suite | 3 | 09-03-2009 08:04 |
BUG in 1.4_b of dctx CAN'T UNLOCK 1600 | Windziarz | UFS2 + UFS3-Tornadoflasher | 13 | 05-11-2006 11:56 |
Wtf Bug In 1.27 !!!!!!!!! | twisterfan | Twisterflasher | 18 | 11-03-2004 21:11 |
Bug in TwisterSuit1.27 | RafalTK | Twisterflasher | 3 | 10-30-2004 09:52 |
