Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-06-2005, 11:40   #1 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
alwas same problem in X600
i have more than 5 X600 in my shope same problem
the problem is : when power on i see samsung and auto of i do all this step
i try other battrey -->Result-----> same problem
i flash it more than 5 different version -->Result-----> same problem
i use all hardware solution if forum : like remouve micro , rehot flash ic ..Result-----> same problem
any one have other solution ?
thx
Old 04-07-2005, 05:47   #2 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
If phone die after circle and Samsung logo then for sure TFS reading is problem - but this can be SW, but can be also bad flash selecting - try to take look detail over switching between bin and tfs zones addressing from CPU ... may be will help you.
Old 04-07-2005, 11:49   #3 (permalink)
OLYMPIOS's Avatar
Member: 93568
Thanks Meter: 44
heh ~ this problem is stil my time 3 months now i do everything but nothing .. read another thread on foroum ,for x600 problems
Old 04-09-2005, 08:46   #4 (permalink)
Aymen G's Avatar
Member: 127608
Thanks Meter: 46
i have 2 x600 same probléme no solution ?????
Old 04-10-2005, 02:13   #5 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
listen to me friends!
If the phone switch off without SIM after it displays (samsung lolgo startup) the problem is software 10000000000 %
I have solved this problem in all the phones gave to my shop (GT : 100 units) !
If the phone shut down oly within sim after geting network ;the problem is hardware and the solution can be the PA, the power IC , oscillator, crystal..)
you must try allabove !!!
the same problem in 3 phone x_man_2002 Nokia Hardware & Hardware Repair 0 11-11-2009 20:38
sir i have same problem in mt 6226ba cpu tarunvishal Infinity-Box 5 02-19-2008 07:56
N70 & 6680 same problem in soft sajidmirza Nokia Hardware & Hardware Repair 3 01-18-2008 19:35
always the same problem in my HWK please fix me the problem MDK23 HWK 5 08-09-2007 19:42
Page generated in 0.18268 seconds with 9 queries
