Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 07-08-2011, 17:52   #16 (permalink)
Member: 414366
Thanks Meter: 5
Originally Posted by stylius View Post
i have same problem. What phone have LTYN ic?
samsung e700 LTYN=LTH7 THIS SOLUTIONS NO GOOD PHONE COLLECTS (TAKE) CURRENT 70ma
Old 07-08-2011, 18:00   #17 (permalink)
Member: 1612145
S5620 display light solution
This is a best solution ever you have
Old 10-06-2011, 18:07   #18 (permalink)
Member: 1598043
hi bro.
s5620 light problem?can you solve it plz.
Old 10-10-2011, 11:02   #19 (permalink)
Member: 1598043
hi bro,could u plz tell me what should i do?what does this picture explain?
Old 10-14-2011, 10:26   #20 (permalink)
HIRENSHAH9's Avatar
Member: 1477622
Sonork: 100.1646445
Thanks Meter: 25
plz any to translet to english
Old 10-31-2011, 19:38   #21 (permalink)
DJ Morgan's Avatar
Member: 120827
Thanks Meter: 126
Just change coil (for example from nokia BB5) and solder it with wires (because of size of original coil), you can place it between oscilator and old coil pads. Old coil sholud be removed
You must use wire, bacause bigger coil can make short-circuit with other signal lines. Remember to use insulator on the pads of new coil.
Good luck!
Old 11-08-2011, 10:29   #22 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 849
fine worked tested...
Old 11-26-2011, 20:43   #23 (permalink)
Member: 1321112
Thanks Meter: 2
thanks a lot raj_shanu, for sharing
in my case s5620 not display it is black screen but it can make a call. I remove L500 out
because it is very hot. and replace with L504 (it is on E250). Now my display is came back.
I just vote...it is worked 100%
Old 12-03-2011, 05:37   #24 (permalink)
Member: 1581340
Sonork: tsd
thanks brow *** bless u
Old 01-13-2012, 12:31   #25 (permalink)
Member: 306994
anyone tell me where i can get thi 6-leg ic
Old 03-08-2012, 10:52   #26 (permalink)
Member: 781628
Sonork: 1645419
thank uuuuuuuuu
Old 04-25-2012, 14:56   #27 (permalink)
Member: 1663259
monte
hi sir pls help me samsung monte light solution........
Old 05-20-2012, 15:37   #28 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
i got 2 5620 light problem only change coil working ok
coil showing continuity but coil failure
coil u can get n70(flash light section), 5130,5310,2700,3110....(light section), n95 (near battery connector)...............etc
Small coil working fine no heat nothing already tested....................
& LTYN i think in all flip samsung mobile in that cable
Old 09-16-2012, 08:57   #29 (permalink)
Member: 1735438
Anyone can help my samsung s 5620 no led,I change coil ok but after 2days.it's come again that problem. Please if you care.
Old 09-16-2012, 08:59   #30 (permalink)
Member: 1735438
Anyone can help my samsung s 5620 no lcd light
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Pic Solution jan Nokia Hardware & Hardware Repair 8 10-11-2010 11:56
5110 version 5.24 solution lampin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-14-1999 07:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 06:55
Page generated in 0.51430 seconds with 9 queries
