LCD Refurbish All things related to LCD / Screen refurbish and repair |
11-23-2015, 20:07 | #166 (permalink) |
Junior Member Join Date: May 2015
Member: 2400293 Status: Offline Thanks Meter: 0 | these chinese laminator and autoclave are not good enough. commercial factories have controlled conditions and precise industrial equipment. for small shops, its hit or miss. sometimes you get 10/10, sometimes you get 1/10. there are just so many variables to get a perfect lcd, and a lot of these variables cannot be controlled by you (such as oca moisture,grade,age or air quality on a particular day,etc..). Last edited by tyroneb; 11-23-2015 at 20:17. |
12-05-2015, 08:30 | #168 (permalink) | |
Junior Member Join Date: Nov 2015
Member: 2489286 Status: Offline Thanks Meter: 0 | Quote:
01-04-2016, 23:24 | #173 (permalink) |
Junior Member Join Date: Jan 2010 Location: Czech republic
Member: 1218061 Status: Offline Thanks Meter: 0 | Hello, I repair with LOCA and now I need work with OCA. Can you help me please choose good machines? I will buy: 1. laminating machine Built-in Vacuum Pump LCD OCA Laminating Machine Universal OCA Laminator For iPhone Samsung LCD Touch Screen Repair 2. Second laminating machine - IS IT IMPORTANT?????? New Arrival OCA Vacuum Laminating Machine Refurbish Repair OCA Laminator LCD Lamination Machine 3. Autoclave Black Mini High Pressure Autoclave OCA Adhesive Sticker LCD Bubble Remove Machine for Glass Refurbishment Is it important have all these machine? Can I work without anything from these machines? Thank you |
01-19-2016, 22:24 | #176 (permalink) | |
Junior Member Join Date: Aug 2014
Member: 2245338 Status: Offline Thanks Meter: 4 | Quote:
Iīm having an issue refurbishing iPhone 6 & 6+ screens, if I change the polarized film, the touchscreen *****, or donīt work, or works with flaws. Iīm also putting the conductive paste in the upper corners... but no idea why this happen. If I donīt change the polarized film, no problems at all, all working excellent, so itīs not the glass ond OCA. If you have an advice, would be great. Thanks | |
01-20-2016, 11:00 | #177 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Hungary Age: 46
Member: 40263 Status: Offline Thanks Meter: 14 | Hi! I handle the adhesive Oca display . Average 20 will be 1 piece bubble . I do not use the machine only Remove Bubble Machine. sorry for my bad english |
The Following User Says Thank You to Lazy2003 For This Useful Post: |
01-21-2016, 05:06 | #178 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2518271 Status: Offline Thanks Meter: 1 | Quote: Originally Posted by Stoyan View Post can you add me, refurbish screens almost 3 years before +35978%€Ģ%_€393 Hi, Iīm having an issue refurbishing iPhone 6 & 6+ screens, if I change the polarized film, the touchscreen *****, or donīt work, or works with flaws. Iīm also putting the conductive paste in the upper corners... but no idea why this happen. If I donīt change the polarized film, no problems at all, all working excellent, so itīs not the glass ond OCA. If you have an advice, would be great. Thanks Hi, I think your problem are the Polarizer you're using in the moment! Try to get good quality polarizer! Last edited by THE CLASH; 01-31-2016 at 17:39. |
The Following User Says Thank You to hitecnology For This Useful Post: |
01-21-2016, 12:10 | #179 (permalink) |
Member: 2245338 Status: Offline Thanks Meter: 4 | Thank you! I ask my supplier several times, always tell me it is Original, and so on... try different supplier, same results, also indicate it is Original Polarized film... Do you have a link to a good polarized film so I can buy to try? Thanks! |
