Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-16-2005, 21:41   #1 (permalink)
Member: 176003
Sonork: bb pin 27883543
Thanks Meter: 74
Red face C100
C100 THE LIGHTS ONLY FLASH,BUT THE PHONE DOESNT GO ON.CAN ANYBODY HELP
Old 09-17-2005, 10:59   #2 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
Hi clebo
I suppose you checked the obvious like "flat battery" the charging ic ****s on those phones often you can bridge it out with a diode, If its not that have you tried to flash the handset?
Regards D.
Old 09-18-2005, 12:43   #3 (permalink)
Member: 168352
Thanks Meter: 18
first of all simply flash d phone
& then reset it
Old 09-19-2005, 21:11   #4 (permalink)
Member: 145868
hi,senior friends,on saturday a customer brought a C100,all keys freezing,after heating the board,the keys started working again, today the customer is back with another problem,phone has full network but does not connect to network provider,always call fail,what is the simple trick to solve this problem?
Old 09-20-2005, 18:26   #5 (permalink)
Member: 168352
Thanks Meter: 18
u can change power amplifier in dis case
Old 09-20-2005, 21:24   #6 (permalink)
Member: 145868
i have gone through the schematic diagram of C100 couldnt find any PA on the phone every thing is connected to power ic.i will appreciate further direction on what to do .
Need C100 flash file ver. C100 JRDA2 THE ARABIC ONE ??? the_frightener VLSI, Conexant, Skyworks and Old Models 7 07-11-2011 11:44
C100 Java Loader Full (Java to C100/C108 ) crack_box VLSI, Conexant, Skyworks and Old Models 3 02-20-2006 10:44
java game for samsung S100, S200, S300, C100 cooler1 VLSI, Conexant, Skyworks and Old Models 1 07-09-2004 05:33
unlock and change emei c100 trongtin VLSI, Conexant, Skyworks and Old Models 6 07-31-2003 06:00
SAMSUNg C100 themobileking VLSI, Conexant, Skyworks and Old Models 6 06-26-2003 14:05
Page generated in 0.21264 seconds with 9 queries
