Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 08-22-2006, 08:55   #1 (permalink)
Registered User
Member: 82693
C100 No Network.....
.....i cant find the solution for samsung c100 "no service" on the forum
pls could anyone inform me what to do to fix the problem.positive responce will be appriciated.
thanx in advance.
Old 08-22-2006, 11:17   #2 (permalink)
Member: 297279
hi,
are you check hardware and pa
Regards, Zakaria Babu
Old 08-22-2006, 13:01   #3 (permalink)
Member: 155401
hi
your set check hardware pam ic white resolt you.
Old 08-23-2006, 06:23   #4 (permalink)
Member: 256886
c227, c228 or rebuild U200
Old 08-23-2006, 08:03   #5 (permalink)
Registered User
Member: 82693
any schema for the solution pls........
REGARDS.
Old 08-23-2006, 08:22   #6 (permalink)
inder's Avatar
Member: 121938
Sonork: 1001590655
REGARDS.
in all samsung mostly thease problem seen ,wait,systemfailure,contact provider, the trick is this for all is the charging jeck, if you clean the jeck
inner and outer throughly then see the result, its work for me
Old 08-23-2006, 10:42   #7 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
I Quite Agree With Inder Concerning What He Said; However, My Experience With Samsung Phones Made Me Realize That The Pa And Antenna Switch Are Usually Responsible In Most Cases For The No Network Stuff. Reheating With A Temp. Of 417 Degrees Celsius And Moderate Air Will Do.
Old 08-24-2006, 05:02   #8 (permalink)
Member: 256886
c100 ------------------
Old 09-14-2006, 18:15   #9 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Question
For what this picture is???????????
Terrible!
Old 09-14-2006, 22:02   #10 (permalink)
r a nadeem's Avatar
Member: 241039
C100
thanx in advance.
first of all try this code *2767*2878# then u should try this , rehot as pic
Samsung C100 ,NO Network arorasatishkuma Samsung Hardware Repair Area 1 09-14-2006 18:40
sgh c100 no network de brain box Samsung Hardware Repair Area 3 09-04-2006 23:19
C100 No Network rishu Samsung Hardware Repair Area 1 04-17-2006 20:52
samsung c100 no network sasel1 Samsung Hardware Repair Area 1 03-22-2005 21:15
c100 ... after playing with some toolz... NO NETWORK .. HELP! Brka VLSI, Conexant, Skyworks and Old Models 29 10-23-2003 10:11
Page generated in 0.44949 seconds with 12 queries
