05-27-2019, 10:18 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2091529 Status: Offline Sonork: 0081351 Thanks Meter: 0 | C3050 / C3053 turns off when sim is inserted !!! i have samsung C3050, without a sim works just fine, but when sim is inserted the phone turns on for a while ( ~30 sec ) and reads the sim, then turns off automatically. and i heve another C3053, it seems to have the same problem but slightly different, without sim the phone works just fine, with sim in it, the phone turns on and reads the sim then reboots automatically and it doesn't read sim anymore. the sim ways are fine as i think and tested. please guys help me and thanks in advance. |
05-29-2019, 01:39 | #2 (permalink) |
Freak Poster Join Date: Mar 2007 Location: u.k
Member: 467279 Status: Offline Thanks Meter: 42 | you know it’s a very common problem on this model. 90% of the cases I found liquid damage in the phone damaging the Sim Ic, it’s a little square one near your sim reader, you can also clean around that with a soft tooth brush and mentholated sprits. Don’t fiddle with your sim contact/ reader if no damage visible to the eye. |
The Following User Says Thank You to kammy6000 For This Useful Post: |
05-30-2019, 23:31 | #3 (permalink) | |
Member: 2091529 Status: Offline Sonork: 0081351 Thanks Meter: 0 | Quote:
Kammy6000 thank for your help, but can you specify the location of this sim-ic, cause what i found around the sim reader are battery-ic, bluetooth-ic and diode-tvs ( which i don't know what is it ). thank you again | |
05-31-2019, 00:35 | #4 (permalink) |
Member: 467279 Status: Offline Thanks Meter: 42 | http://forum.gsmhosting.com/vbb/f258...t-sim-1175876/ http://forum.gsmhosting.com/vbb/f258...t-sim-1616123/ another trick cover each pin 1 at a time with small tape you will find problem pin! or put tape on sim section one each pin test it |
06-11-2019, 23:32 | #5 (permalink) | |
thank you Kammy6000 your solution worked just fine | |
