Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 01-27-2013, 10:46   #1 (permalink)
anwar.welltech's Avatar
Member: 952533
Sonork: 1001607366
Thanks Meter: 122
c3312 headphone mode
c3312 headphone mode, removed hf connecter and charging jack still prblem , plz help me experts
Old 01-27-2013, 14:45   #2 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 5,483
C3312 handfree Problem
Tips way or workmanship when the exit profile headset:
1. Mobile opened the chassis and is powered using batteries
2. Set the voltage at the 2.8 Volt Power Suply
3. Attach the ground wire to ground PS PCB
4. Give the PS voltage 2.8 V to the legs with a plug-in handsfree note lcd screen at the point where the voltage had been able to change the handsfree profile
5. If there are changes, voltage 2.8 V jumper to the point of other working voltage
6. Just sharing the experience may be useful
Tested on all hp comes out due to the headset profile 2.8 V working voltage is lost.
Before jumper voltage, it could also throw component (capacitor / resistor shorting) the path
dont forget to click thank
The Following 2 Users Say Thank You to d-Artigo For This Useful Post:
Old 02-09-2013, 08:51   #3 (permalink)
Member: 195160
Thanks Meter: 4
C3312 head set mode
ans- charging pin just washed than your hand set 100% good work ok.........
The Following User Says Thank You to microhard_6600 For This Useful Post:
Old 05-24-2013, 20:37   #4 (permalink)
Member: 1853602
Sonork: 000000
Thanks Meter: 10
The Following 3 Users Say Thank You to rajkumarrana.83 For This Useful Post:
Old 01-23-2016, 13:18   #5 (permalink)
Member: 932892
Sonork: 3105
samsung b313e
samsung b313e hedafree mode solution
Page generated in 0.33071 seconds with 7 queries
