champ c3303 any body plz samsung champ c3303 speaker and mic not work in same time` what is the problem |
My cell Same problem Speakar not wark plzz help you all Gsm sir |
try headset only you use, if ok, the probably error is switching Ic. |
i hv same problem... call with headset is ok.. call with buzzer/loud speaker ok.. but speaker n mic not working... help plz......... |
change crystal mic ur problam is solved |
Can nokia crystal mic be used or it is different |
Not good solution yet can any one focus on this thread? Pls i am aslo suffiring same problem,, Thanks |
try canging the usb jack and the filters below it reflow mainboad,or remove the mic and see if speaker working if it is then the problem is the mic causing the issue |
yes i have same problam any body help pls............ |
i have same problem to,i try to change mic but phone won't startup,speaker still not ringing... I try to rehot ic in 3 different place,near sim slot,jack slot and near vibra now i have sound radio only (bzzz... No channel),when before not work... Any suggest or jumper trick should i try,sir?... Sorry,my bad english... |
