Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-04-2006, 16:45   #1 (permalink)
Member: 380145
d500 fault
ok after 3 ribbon cables fitted the same problem exists, when turned on and being used the backlight to the screen is off , you can see everything on the screen as it should be but very faint as the main light has not come on?
also on my other d500 evrything works except after pushing the menu button the screen and pixels change to just coulors no images just blocks then when you leave that part :ie the first menu everything gos back to normal as if it cant show the menu picture? any ideas?? please a si have bnow two phones that dont work properly
Old 11-04-2006, 17:20   #2 (permalink)
Member: 21192
Thumbs up d500 fault
have you soldered the 2 connections properly on to the board the joints have to be perfect or the lcds dont work other option is you have a faulty screen from new had this prob many times
Old 11-04-2006, 22:28   #3 (permalink)
Member: 380145
thanks for that , no i did not solder it on as it came with it already done
Old 11-06-2006, 08:19   #4 (permalink)
Member: 21192
d500 fault
must be fault either on lcd itself or on the front board then
d500 pbm verif batery temp pbm please help me amirgsmbejaia Samsung Hardware Repair Area 0 03-29-2010 15:33
d500 camara fault mobileZONE Samsung Flashers, Software, Firmware. 2 08-03-2006 21:00
D500 camera light fault?? plz help??? Kreg26 Samsung Hardware Repair Area 1 04-11-2006 12:59
D500 flashing fault teerak2uk SWIFT Platform 1 09-09-2005 07:44
Page generated in 0.24586 seconds with 11 queries
