01-12-2006, 18:21 | #4 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | what not working here? if it is the main keypad (123456789*0#) then please remove the back cover and check that the volume and camera keys are properly alligned fluch against the black rubber part (not pushed under it). that will cause the volume/camera key to be pressed down so no other key is respond... if it is screen board keys not work (green, red, scroll), then please check the bottom two screws in the LCD housing part. if they are over tight then these keys will fail. as always, check key pad and dome sheet for corrosion, clean if required... after this, your problem is down to processor almost for sure as keys are linked direct to there.. |
01-13-2006, 12:06 | #5 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: lebanon Age: 45
Member: 68311 Status: Offline Thanks Meter: 34 | Quote:
USB Warming Mouse Pad/ USB Heating Pad | IPMART | ipmart WebShop | 0 | 12-04-2009 14:20 |
w550i,the 2,8,# not working.. changed 3 key pad ic,, key pad noww what to do??? | broken_rules | Sony Ericsson Hardware Repair | 2 | 03-20-2009 15:44 |
D500 R205 removed, pad ripped... | Dave.W | Samsung Hardware Repair | 5 | 09-06-2008 14:06 |
D500 Key Pad Lights... | dragc | Samsung Hardware Repair | 2 | 11-14-2005 12:19 |
if your pcb pad cut off ,or lost pad | willy | Nokia Hardware & Hardware Repair | 9 | 08-30-2004 18:53 |
