Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 01-20-2010, 01:25   #1 (permalink)
Member: 1135448
Sonork: afride
Thanks Meter: 4
d500 samsung
when i connect with charging then its turnig on and when i take of the charger then its turn off i have change the flex but problem is same can u tell me whats the problem.
also during the charging on of
Old 01-20-2010, 01:45   #2 (permalink)
powerlogic's Avatar
Member: 1133716
Thanks Meter: 282
try to change battery
or phone is shorted....
Old 01-20-2010, 15:08   #3 (permalink)
Member: 772941
Sonork: 112
Thanks Meter: 349
First make service your mobile then check charge connector.
Old 01-20-2010, 16:14   #4 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
brother if ur battry is ok then it is % flex problem
Old 01-20-2010, 21:03   #5 (permalink)
xpert's Avatar
Member: 14554
Sonork: None
Thanks Meter: 49
Re:
hi,
check battery, If Ok, mostly yu have shorted board.
Mainly check the Power Amp Module in the RF Part
(check if heated when try power on)..Also, If flex is low quality replace first.
Xpert
how to unlock d500 samsung phone doomstyle SWIFT Platform 6 08-06-2005 20:54
Has any one reimei D500 samsung with twister??? KHEANG SWIFT Platform 4 06-16-2005 10:01
need new d500 samsung full set MELME Wanted Products 1 06-04-2005 15:10
D500 samsung after same times battry low esprilarge2002 SWIFT Platform 0 04-26-2005 15:48
sheme of D500 samsung cable leroi SWIFT Platform 3 04-18-2005 21:17
Page generated in 0.17084 seconds with 9 queries
