09-30-2006, 16:10 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 300043 Status: Offline Thanks Meter: 360 | D500 Vol. Trick Enter the following code:*#8999*8378# (You'll be shown a menu, then) go to:"H/W test" then go to:"Audio Settings" then go to:"Melody Gain" There you will see a number. there are five Melody Levels, and currently, you are at level 1 and after pressing the "save" button, you will move to level 2 and so on you have to change the values of all the levels. and as the result, it will increase the melody sound, your tones will more louder, even more louder then the max. ringing volume. the level wise numbers are: (as its my setting) Melody Level 1: 13 Melody Level 2: 17 Melody Level 3: 18 Melody Level 4: 25 Melody Level 5: 31 you even can make your own combinations of level wise sounding numbers that can change the sound level!. ************ CAUTION ************ if anything goes wrong, then you can apply the master reset code, this will NOT delete anything,from your phone, but set each and eveything to its default setting ... the master reset code is: #*7728# ************ CAUTION ************ TESTED ON A SAMSUNG D500 WORKING FINE |
Gsm Tricks V4.1 all tricks in one soft | foufou | Various | 108 | 12-17-2012 06:52 |
d500 pbm verif batery temp pbm please help me | amirgsmbejaia | Samsung Hardware Repair | 0 | 03-29-2010 15:33 |
D500 tips and trick over here!!!!!! | austinchan | SWIFT Platform | 4 | 06-07-2005 14:40 |
