01-25-2006, 09:49 | #1 (permalink) |
Junior Member Join Date: Jan 2006
Member: 225069 Status: Offline Thanks Meter: 0 | D600 water damage - disassebly? can comeone help me with an Idiot's guide to dis-assemble the D600 so that i can clean the water damage. Phone powers itself on and off and flashes. Also the mic does not pick up sounds etc. lots and lots of wierd stuff. thanks |
01-25-2006, 18:06 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | below i describe, wit phone screen facing down. -remove battery -remove four screws in back -use jimmy tool to remove back cover -carefully flip board and remove ribbon from connector -take out 6 screws you see. phone is now in half -remove two rubber bungs from top of phone -remove all four screws you see -remove screen board from screen housing. please, when opening and closing connectors, try to work at both ends at same time. not from the middle, as you will break black supporting clip in half... that is it btw, i recomend you take to a profesional for this task. you will need (minimum): philips head screwdriver jimmy tool new ribbon you will need (maybe) ultrasonic bath rework station |
D600 water damaged, Restarting... | Elias Khan | UST Pro II | 2 | 08-24-2008 16:06 |
Samaung D600 - Water Problem | markysparky89 | Samsung Hardware Repair | 0 | 11-27-2007 03:19 |
Water damage D600 | rodman999 | Samsung Hardware Repair | 3 | 08-04-2006 11:09 |
water damaged 5110 | gsmxc | Nokia Hardware & Hardware Repair | 5 | 10-18-2001 16:15 |
3210 *water damaged* no reception | pks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-28-2001 12:09 |
