03-23-2007, 17:31 | #1 (permalink) |
Major Poster Join Date: Jan 2005 Age: 66
Member: 106942 Status: Offline Thanks Meter: 0 | D900 Just Keeps Flashing Up Samsung Screen My new D900 Phone just keeps recycling on startup, it flashes up the samsung startup screen then goes off then back on again and just keeps in this loop. It was ok until I turned it off then all this started on the next switch on. Anybody any ideas on a fix, or does it need flashing. flack . |
03-26-2007, 22:44 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | have the same problem but in my case occured when it got in contact with water. Flashed it with a full flash and still the same. When trying to unlock it TAT mode shows up and then TAT mode goes and wont unlock. Tried to see if it was a fault from the screen part maybe a short but same occurs without a screen. Unlocking fails completely. Anyone having some info would help me save this one up? thanks a lot |
03-27-2007, 02:00 | #3 (permalink) | |
No Life Poster Join Date: Feb 2005 Age: 44
Member: 115826 Status: Offline Thanks Meter: 391 | Quote:
03-27-2007, 18:30 | #4 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | wont get in that state mate. Once pressed power D900 screen shows up and then restarts and keeps on going like this. Tried full flash and still the same. |
03-27-2007, 19:55 | #6 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | not LCD for sure. i tried to unlock the board (since this model does not need a battrey inserted to get in TAT mode) using nspro and got same result. IF it were from LCD guess it would have unlocked it ok. thanks for helping mate. |
03-27-2007, 20:04 | #7 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 461058 Status: Offline Thanks Meter: 8 | I got this problem with a D600 that rebooted once the phone gets network , I changed lcd so it been all good But if there is on the board I got no idea, so it means when you've flashed it you cannot reset the phone then right ? Please even check if there is not short somewhere , especially on board 2 board connector pins Regards Jack |
03-27-2007, 20:06 | #8 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | Dear just rehot normaly your mother board,i hope after reheating your problem will be solve. But if lcd is woking well. BR Kashif Khan |
03-27-2007, 22:19 | #10 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | sure i did reflow all the SMDs. There are only a couple of BGAs present :P one last resort would be to use the ultrasonic bath since dont have parts to try and replace this D400 which seems to be responsible for power in this set. thanks guys for helping |
03-31-2007, 19:11 | #12 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | some update on this one. managed to revive it .... dipped it back into water using sonic bath, dried it up, re-flowed ever part again and back to life. However discovered that the charging port is ****ed up for good and need to replace it. Now the problem is that i cant find any of this damn ports |
how to repair C3010s just show samsung screen a while then it off | mantok | Z3X-Team Products | 0 | 01-04-2010 19:14 |
nokia 6300 rm 217 after flash just nokia show then white screen | shani72 | Nokia Hardware & Hardware Repair | 7 | 11-22-2008 05:57 |
Nokia 1100a RH-38 Just keeps on Blinking when Powered ON ! | Tanvir | Nokia Digital Core Technology 4 ( DCT-4 ) | 25 | 08-08-2007 12:21 |
d900 camera flash operating with screen lights. | thephoneman | Samsung Hardware Repair | 0 | 06-09-2007 03:11 |
U8120 just keeps turning on | tical | Cruiser Suite | 0 | 01-28-2007 11:08 |
