06-30-2008, 09:51 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Balkan Age: 47
Member: 640416 Status: Offline Thanks Meter: 16 | D900 slider not active Does anyone knows what is solution for this problem? |
12-04-2008, 13:40 | #5 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Uruguay Age: 39
Member: 806365 Status: Offline Thanks Meter: 42 | hello friend! The magnetic sensor is located below the keypad, look at this place clean and dry. lifting the plate and a rubber protective you have left in sight. luck. |
11-16-2011, 13:46 | #7 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1689286 Status: Offline Thanks Meter: 0 | D900 slider solution HI FRIENDS I have found the magent! It is located on the bottom of the panel that the lens is on and is a small, thin peice of metal covered buy some yellow glue and is about 10mm long and 0.2mm wide. Hope this helps others!! PM me if your having difficulty finding it |
D900 sim lock active cell is already country unlocked | ghulamabbasi | Samsung Flashers, Software, Firmware. | 0 | 03-09-2010 14:00 |
D900i slider is not active slide up or problem | looupss | Samsung Hardware Repair | 4 | 04-25-2009 09:59 |
n95 Screen light and buttons on slider not working | goasim | Nokia Hardware & Hardware Repair | 4 | 12-24-2007 19:31 |
pinout for n95 slider not work | SGHGSM 3 | Infinity-Box | 4 | 12-03-2007 09:05 |
D600 Active Slider not working | kruze | Samsung Hardware Repair | 2 | 08-24-2006 20:03 |
