Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 07-02-2012, 16:18   #1 (permalink)
Member: 21937
Thanks Meter: 278
E:format_volume: rfs format failed on/dev/block/mmcblk0p2
any solution for this problem in i9000?
after any flash of any frimware
if i go into recovery and try wipe data of phone , same prblem.
it seem internal memory is bad ? any solution other then replacing the chip >?
Old 07-05-2012, 02:13   #2 (permalink)
Member: 1763229
Thanks Meter: 7
Flashing stock rom with re partition ticked fixes this problem or use repair kit
method one
Try and get a hold of Stock Gingerbread firmware with individual files (including bootloaders) like JVZ Firmware
use odin
Procedure:
1. Get the phone to the Download Mode
2. Select PIT (usually 512)
3. Select BOOTLOADER (APBOOT)
4. Select PDA (CODE)
5. Select PHONE (MODEM)
6. Select CSC (CSC)
7. If 'Re-Partition' is not checked under 'Option', check it.
8. Press the Start button
method 2
use rescue kit
Hotfile.com: One click file hosting: SGS_Rescue_kit-13-1-2012.rar
Old 07-11-2012, 15:21   #3 (permalink)
BIGUNLOCKSERVER's Avatar
Member: 1542932
Sonork: 100.1621006
Thanks Meter: 53
Hard Reset Samsung Android Phones Easy
Old 07-12-2012, 10:54   #4 (permalink)
Member: 1487630
Sonork: 100.1621007
Thanks Meter: 39
ur efs is damaged repair efs via riff box it will be ok
Old 07-14-2012, 09:41   #5 (permalink)
Member: 21937
Thanks Meter: 278
phone is no longer in here.
i couldnt fix it.
from all my search its something with bad internal memory.
i saw online ppl could fix this problem with external memory card but couldnt find the way to do it.
next time i'll try riff
Old 02-17-2014, 12:20   #6 (permalink)
Member: 1183382
Sonork: 1658787:3737
Thanks Meter: 2
link not working.....................
Old 02-21-2014, 14:08   #7 (permalink)
Member: 2071735
Thanks Meter: 8
plz another link send
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 09:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 21:09
Page generated in 0.22636 seconds with 8 queries
