E2152 power off when charger connected. Can any one help.E2152 turn off when charger connected (charger plugged to ac).if charger unplugged and i put charging jack than set remains on ,as soon i plug it to ac set goes off. |
chek battery connector for karbon |
change ZD105-OK-----------THANKS |
DEAR MASTER PLS CHANGE CHARGING SOCKET Regards Palmobile @Service Team |
meeter chek bsi pass ok but not working plz make jumper |
Change battery 100000000000000000 work |
yes battery problem, battery's center point BSI stop working it may gives less -ve supply |
charging no battery problem:( |
Well to be sure you need a power supply will connecting the charger on the same time and decrease or elevate the voltage of Power supply doesn't matter what matters is to read on power supply hight amperage without letting power supply restart When you have this case you will start feeling ic's getting hot Change it and check & test capacitors arround to see if broked or shorted and replace You can as well change charger connectore Only thanks botton |
1 Attachment(s) Quote:
replace charging ic take replacement from china phones it is 6 pin ic pt116 |
how to find ways of any componen using avo in samsung core 2 method how to find charging track how to find data pins |
