E2152i & sum other only showing charging not filling batter 100 % tested solution :) if samsung e2152i and other samsung models which have same charging ic similor wid e2152i shows only charging but not filling battery then find charging ic having 6 pins and check all pins 1 pin will show current about 4v or 4 + and find other pin which goes to battery + point ... and short these 2 pins ........ it will solve ur problem of battry not filling ..... here is one example of e2152i which i have done by shorting charging ic's two pins ........ http://i41.tinypic.com/eju5tx.jpg this solution will only work for only showing charging but not filling ..... and am very very sorry for my bad english :P ..... thx regards:- K@rnv!r $!NGH |
Thanks you so much for your good post, it is really helpful Keep it up always brother............... |
samsung 2152i chircing plag in but so is pc canact piess help |
good job .................................. |
