06-26-2008, 14:02 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: world wide
Member: 57836 Status: Offline Thanks Meter: 47 | E250 after removing charge connector, LCD becom Blank because the the charger connector is damage, and it makes contact between some legs, and we think that makes battery going down, we removed it, but after that the lcd become blank, i tested an other main-board, and the lcd working ok, and i tested the board that' i removed the connector in other phone, it's allways blank lcd, how is possible whene removing the charge connector, the lcd becom blank, how can be solved thius problem pleas, help thankx |
The Following 3 Users Say Thank You to fethi For This Useful Post: |
06-26-2008, 15:26 | #4 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | Did u removed by hot air? Quote:
The Following User Says Thank You to GSMsurgeon For This Useful Post: |
06-26-2008, 16:52 | #5 (permalink) | |
Member: 57836 Status: Offline Thanks Meter: 47 | Quote:
but the flash ic & cpu are a bit away from the place of work, i don't think one of theme is damaged by over heat | |
The Following User Says Thank You to fethi For This Useful Post: |
06-27-2008, 11:42 | #6 (permalink) | |
Freak Poster Join Date: Oct 2006
Member: 381171 Status: Offline Thanks Meter: 52 | same problem for me Quote:
i also do changing the charging connector display becomes white. but i cover the flash ic and cpu with metal shield. what solution ??????????? | |
The Following User Says Thank You to inaam143 For This Useful Post: |
10-18-2008, 10:59 | #11 (permalink) |
Member: 57836 Status: Offline Thanks Meter: 47 | well, the all here, it's highly reccomended for not changing the charger connector for samsung E250 because the job can damage easy the phone, and it is not possible to repaire back the phone, as i think it's fabrik fault this is my opygnion thank you |
12-12-2008, 18:36 | #14 (permalink) |
No Life Poster Join Date: May 2005 Age: 61
Member: 147694 Status: Offline Thanks Meter: 69 | Hey Bro i have this problem the charger connector is damage, and it makes contact between some legs, and we think that makes battery going down, we removed it, but after that the lcd become blank, i tested an other main-board, and the lcd working ok, and i tested the board that' i removed the connector in other phone, it's allways blank lcd, how is possible whene removing the charge connector, the lcd becom blank, how can be solved thius problem pleas, help thanks pls shematic for this problem.. |
01-19-2009, 14:39 | #15 (permalink) | |
Freak Poster Join Date: May 2008
Member: 767784 Status: Offline Thanks Meter: 21 | e250 Quote:
X820 after change charge connector NO RINGER ????? | .:RoMeO:. | Samsung Hardware Repair | 8 | 07-06-2011 15:52 |
What is the Best Way to Remove Charge Connector of Samsung Phones | powerplay83 | Samsung Hardware Repair | 6 | 07-14-2010 03:11 |
samsung p910 damage after changing charge connector | fethi | Samsung Hardware Repair | 2 | 01-01-2010 21:26 |
e250 no lcd after change charging connector | abdel7650 | Samsung Hardware Repair | 6 | 09-01-2009 08:51 |
N72 white light after changing charging connector | mukeshdurg | Nokia Base Band 5 ( BB-5 ) | 2 | 04-04-2009 19:35 |
