Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 07-31-2009, 18:12   #1 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Red face E250 call ended problem!
E250 network bar full but no incoming no outgoing whean i try to calling allways says call ended.I all redy full flash write eprome change pa,antina switch but same sumbody tell now what can i do?
The Following User Says Thank You to Shantobhai For This Useful Post:
Old 07-31-2009, 18:52   #2 (permalink)
Member: 109755
check imei-rebuild imei
flash eeprom
if not check HW
Old 08-01-2009, 05:39   #3 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
flash eeprom
if not check HW
I alredy do that any other solution??
Old 08-30-2009, 19:33   #4 (permalink)
Member: 343635
did you solved the problem? i have the same problem on a e250
Old 07-17-2010, 10:43   #5 (permalink)
Member: 518978
brdr.. I have too e250 ..with same problem..!!!!!
Old 07-25-2010, 00:14   #6 (permalink)
Member: 430865
chek IC U106 and U103 change or air hot it work at 60%
spice s404 call ended problem aman.smart Nokia Hardware & Hardware-Repair Area 0 03-29-2010 20:48
e250 call ended timberland2 UST Pro II 5 03-29-2009 08:24
What's wrong d500 & e250 call end. karlleeto SWIFT Platform 3 09-30-2007 06:34
X530, X830, E250 call ended. mishaelwillo Trident/AGERE Platform 1 06-14-2007 18:16
a35 call ended problem mohammed x1x to x45/x50 23 09-29-2005 14:26
Page generated in 0.31941 seconds with 11 queries
