11-15-2008, 09:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | First try to this code (*2767*3855#)ur pro will be solved if nothing then rehot the charging ic ur prob will be soveld 1000000%ok and reply Guljeeeee |
11-17-2008, 09:00 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Rawalpindi Pakistan Age: 45
Member: 190947 Status: Offline Sonork: 100.96272 Thanks Meter: 161 | e250 hang change the power ic e250 hang change the power ic i chak this solution 100 % working this solution working only e250 not e250 d becoz his power ic is difrent and also charging unit also in power ic br Ms Communication pakistan |
11-20-2008, 12:02 | #8 (permalink) |
Freak Poster Join Date: Mar 2006 Location: In a house Age: 46
Member: 249757 Status: Offline Sonork: 100.1601084 Thanks Meter: 117 | I dont understand this picture U saying remove Power IC and bridge to pin9 on system connector?? Or change Power IC??? without power IC phone cant switch on! phone cant charge, Power IC supplies power to Baseband (Cpu) and other components..... So what are u saying here? You're picture doesnt make any sense. As for phone freezing when playing videos or using the camera: have u changed the flex or camera? U try software? |
The Following 2 Users Say Thank You to Speed_Demon For This Useful Post: |
11-26-2008, 12:41 | #10 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | Quote:
this solution dont work for hang e250 but for auto power off after powering on.for the power ic dont remove it because i use the modify picture. b.r toutou_gsm | |
The Following 2 Users Say Thank You to toutou_gsm For This Useful Post: |
e250 hang in startup screen | pyjaman | UST Pro II | 31 | 09-30-2010 07:26 |
E250 Hang at SGH-E250 100% Tested Solution | abdul4gsm | Samsung Hardware Repair | 22 | 06-06-2010 17:22 |
E250 hang on sgh-e250 !!!!! | msantar | NSPRO | 5 | 02-09-2009 13:54 |
E250 hang on sgh-e250 | msantar | SWIFT Platform | 2 | 11-20-2008 15:08 |
E250 hangs | ISKISH | SWIFT Platform | 0 | 05-23-2007 15:00 |
