01-04-2009, 11:32 | #1 (permalink) |
Registered User Join Date: May 2007
Member: 504492 Status: Offline Thanks Meter: 30 | E250 Power Button I have samsung e250, it has lcd problam, i.e some time it is white and some time is an irregular shape and also it is ok when the slide is in downward. Now its Power Button also does not work. what is the probalm and what i do? Plzzzz help me....... |
01-04-2009, 11:57 | #2 (permalink) | |
Junior Member Join Date: Nov 2008 Location: PVJ
Member: 902935 Status: Offline Sonork: 251185 Thanks Meter: 4 | Quote:
its flex problem, change it with a good one.. | |
03-01-2009, 07:58 | #8 (permalink) |
No Life Poster Join Date: May 2007 Location: INdIa
Member: 517316 Status: Offline Thanks Meter: 185 | Changing Strip Does not help Always............ Some times it is Hardware fault If anyone have on/off ways for e250 Please post here I've Tried But no luck Only Red(on/off) button is not working and set is not powering on..... |
04-16-2009, 17:31 | #10 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | NOT DONE BY THIS ALSO, ANY OTHER SOLUTION? THE power key goes to u403 direct after diod i have removed that diod, but same, changed strip also, any other solution? |
08-23-2010, 15:27 | #12 (permalink) |
Junior Member Join Date: Nov 2008 Location: www.zxsheng.com
Member: 908534 Status: Offline Sonork: m_ihlas Thanks Meter: 0 | e250, 250d, 250i on off and red button solution is :just check keypad connector on main board and main keypads flex connector... tested by me 4 times luckily |
N700 button not working except power button | gbada | Samsung Hardware Repair | 11 | 06-16-2006 16:05 |
x480 water damaged.... to power on have to keep power button pressed | Burnt Cobba | Samsung Hardware Repair | 2 | 03-21-2006 17:08 |
V802 "press power button then flash camera light but not power on" | deepcook_dalat | Cruiser Suite | 0 | 09-16-2005 03:44 |
GX10 Only power ON with finger kept on power button | yeldar | Sharp | 2 | 05-21-2004 20:49 |
n105 power on only with power button pressed... | jokkergsm | VLSI, Conexant, Skyworks and Old Models | 17 | 05-06-2003 17:37 |
