12-05-2010, 08:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Scotland
Member: 50067 Status: Offline Thanks Meter: 40 | e250i not charging. Voltage issue? It will not charge with the original charger, but it charges using usb cable (pcb220bbe) and usb mains plug. I measured the voltage across the charging connectors on the handset and usb cable is supplying 2.8V Original charger is supplying 1.6V Is original charger faulty? or could it be fault/short on pcb? Thanks. MK5 |
12-12-2010, 18:58 | #4 (permalink) |
Member: 50067 Status: Offline Thanks Meter: 40 | Anyone help with this please? I removed pcb and cleaned it etc. Result is the same, but.... Original charger is supplying 5V @ 700mA Usb charger supplying 5V @ 1000mA I measured these immediately after the plug (socket end) but before connecting to handset. Both chargers are supplying around 5V Voltages at battery terminal is now- original - 1.45V usb - 2.99V Is it possible that the original charger is faulty at the handset connector end? Also what should the optimum voltage at the battery connector terminals be? Should it be around 5V to match the output of the charger or 3.7V to match the output of the battery? Thanks. MK5 |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
