09-17-2005, 21:17 | #1 (permalink) |
Insane Poster Join Date: May 2004
Member: 65640 Status: Offline Thanks Meter: 0 | E630 White Screen problem!!!(Not Flex Cable) |
09-18-2005, 23:47 | #3 (permalink) |
Member: 65640 Status: Offline Thanks Meter: 0 | Why would I do full flash if all the fuction is well including dalling? Also the screen does comes out sometime(around 1 every 50 times hehe)so I don't think it is the software problem either....... now I have a D500 with the same symtom(one in a while screen comes up) but it is all spotty instead of white.....anyone have an idea? thank for the idea though |
09-19-2005, 20:12 | #4 (permalink) |
Insane Poster Join Date: Feb 2005 Age: 48
Member: 119993 Status: Offline Thanks Meter: 2 | Dear brother, I have same problem in E800. White screen and all functions are OK. Original flex cable is good. It has 51 lines and I tested. All channals has connection. But I changed with new one. Result is same. I cleaned the sockets but same result. Very sometime, It appeared distored and horizontel white lines display. Please help me... Thanks alot.. Yours Lovelysupercat |
09-19-2005, 20:22 | #5 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | Hi I thinks for E800 is 100% hardawre problem, i have solved by changed connector because connector is very sensible to make contact, you need change it thanks |
09-20-2005, 18:40 | #6 (permalink) |
Member: 119993 Status: Offline Thanks Meter: 2 | Dear BouRRi GSM,,,, Thanks you for your help. I saw the scar on contact point of flex cable. It is mean connector connect very well with flex cable. Is it? Which one did you change? Main connector or Sub connector? I saw both side are good. I will try to test for connection. Thanks alot Yours Lovelysupercat |
N70 White screen BUT NOT HANGING!! | zakiyyboss | Nokia Hardware & Hardware Repair | 8 | 12-05-2007 13:17 |
Nokia 6111 white lcd but not flex HELP | maniek27 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 07-06-2006 20:47 |
Nokia 6260 white screen, but not after flashing... | vatera9 | WD2 & APE (Symbian Phones) | 0 | 03-26-2006 09:46 |
