Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 02-04-2005, 16:23   #1 (permalink)
Member: 102223
e700 camera problem (no flexcable fault)
Overhere I have an e700 from t-mobile (firmware e70bow13)
When I go to the camera it freezes. The mobile doesn't react to anything.
So flexcable or camera fault? no. Tried it with another mobo attached to it and camera works.
So what can it be? Is it a problem that anybody knows of?
It must be either the firmware or the mobo ?
If it's firmware which one can I use as an update (pref. non branded dutch language)
Thanks
Old 02-04-2005, 16:39   #2 (permalink)
arjjun's Avatar
Member: 94224
u try flashhhhhhhhhhhhhhhhhhhhhhhhhh
Old 02-04-2005, 16:47   #3 (permalink)
Member: 102223
Thought so
Where can I find a full dump/flash that suites my needs
unbranded/dutch language
you can pm me if that's better
Thanks
Old 02-05-2005, 19:05   #4 (permalink)
cellularry's Avatar
Member: 42276
If flashing did not help, you should change camera IC
Old 02-05-2005, 21:03   #5 (permalink)
Member: 15476
you neded clean conector very very good with izoprophilic alchool...i refer conector flex and pcb...b.r.
Old 02-08-2005, 21:06   #6 (permalink)
Member: 103401
the last chance try to remove 2 varistors near flat cable connector (VR701, VR700).
This solution help me several times, each time after phone liquid damage, when picture in camera mode is green and freezing.
E700 Camera problem GSM SNIPER Samsung Hardware Repair Area 22 09-15-2004 19:18
E700 Camera problem Wakizashi SYSOL Platform 5 07-16-2004 06:28
E700 camera problem atashius Samsung Hardware Repair Area 4 07-10-2004 13:53
e700 camera problem gsmrepair1 Samsung Hardware Repair Area 5 06-07-2004 16:21
E700 camera problem matab SYSOL Platform 1 04-25-2004 01:59
Page generated in 0.34551 seconds with 11 queries
