E700 display too bright I have an E 700 when I switch on the display goes too bright, but not every time. Someone has some idea of as I can repair it? Thanks |
Ive had that once,i stripped thd lcd from housing and serviced it.solved the problem.all the hardware components are underfilled,so makes difficult to work with!!! |
Could you please explain to me how did you stripped the LCD?? |
detach the lcd from the housing by unclipping all atachments.using a fine tipped oldering iron i the resolder all joins....capacitors...resistors...etc.reassemble the handset..technical work!!!! I LOVE IT!!! |
Thanks for now. I will try it out and keep you informed. |
Before I serviced the display, I notice that, when the display is too bright the camera works with white display (I can see a good image if I close a little bit the flip), but when the display is good the camera gave me “preview error”. I serviced the display but remain the same. :( |
Try changing the lcd,sometimesthe actual crystal gets damaged.... |
this may be will help.. |
test the mother board replce the flat cable test the connector cable check the ltyn ic |
hello all my wife has the same problem with her e700 please can you tell me where i can get a new flat cable camera works fine if only half open hinge our using outer screen thanx for your help |
i guess its stupid common problem.. we neeed a solution here.. please anyone here wiv any help.... thanks.. |
