Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones. |
| | #1 (permalink) |
| Junior Member Join Date: Jan 2005 Age: 44
Member: 110046 Status: Offline Thanks: 0
| E700 display too bright I have an E 700 when I switch on the display goes too bright, but not every time. Someone has some idea of as I can repair it? Thanks |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: At Worknetwork Age: 35
Member: 104528 Status: Offline Thanks: 1
| Ive had that once,i stripped thd lcd from housing and serviced it.solved the problem.all the hardware components are underfilled,so makes difficult to work with!!! |
| | #4 (permalink) |
| detach the lcd from the housing by unclipping all atachments.using a fine tipped oldering iron i the resolder all joins....capacitors...resistors...etc.reassemble the handset..technical work!!!! I LOVE IT!!! |
| | #6 (permalink) |
| Before I serviced the display, I notice that, when the display is too bright the camera works with white display (I can see a good image if I close a little bit the flip), but when the display is good the camera gave me “preview error”. I serviced the display but remain the same. |
| | #11 (permalink) |
| Major Poster ![]() ![]() Join Date: May 2003
Member: 28794 Status: Offline Thanks: 0
| hello all my wife has the same problem with her e700 please can you tell me where i can get a new flat cable camera works fine if only half open hinge our using outer screen thanx for your help |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| E700 Backlight too Bright | The Beast | NSPRO | 1 | 05-18-2006 10:15 |
| E700 Backlight too Bright | The Beast | Samsung Hardware Repair Area | 0 | 05-17-2006 20:32 |
| C100 too brightness display problem | vladut_v | VLSI, Conexant, Skyworks and Old Models | 1 | 03-04-2004 19:18 |
| C100 too brightness display problem | vladut_v | Samsung Hardware Repair Area | 0 | 03-04-2004 14:15 |
| C100 too brightness display problem | vladut_v | Trident/AGERE Platform | 0 | 03-04-2004 11:20 |
