02-01-2007, 23:15 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | E700-melody OK but no sound when call -The flex is ok because I had tested with another pcb -I had found here on forum a solution to connect a wire between 2 contacts of the handsfree conector but the voice volume is very,very low,I can't hear the person who I'm talking with-It's better then no sound at all,at least Is's a start -I also found a solution by removeing a black circuit but It doesn't working (I had a A800 in this condition that I had repaired it with this solution,but on e700 it doesn't work!!!!!!! -It's not a soft problem because I had fullflashed the phone and I had made full reset with that code,I am sure that it's a pcb hardware problem -Can someone give me working and tested solution for this problem |
06-21-2007, 16:09 | #5 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Sargodha Pakistan
Member: 251247 Status: Offline Sonork: 1001670304 Thanks Meter: 192 | Ok..first of all u made a question and then u were waiting for answer but when u found the solution then why not post here? Munazzam. |
06-25-2007, 22:46 | #7 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | The solution was toconnect a wire between 2 contacts of the handsfree conector,I had found here on forum a picture but was shown wrong the pins that had to be conected ,In the end I tryed to conect the last 2 pins and evreything went ok. |
Q33 ringer ok -songs ok but no sound when called | mukeshdurg | Chinese Models & Cloned Phones | 0 | 11-05-2009 15:19 |
d500 ring ok but no sound in call | llcoolr | Samsung Hardware Repair | 20 | 04-04-2009 08:33 |
need mic way ok but no sound | sopnil | Philips | 0 | 01-26-2008 15:11 |
C100 RING TONE OK , BUT NO SOUND IN MIC & SPEAKER | eng.hamdow | Samsung Hardware Repair | 5 | 02-19-2006 18:31 |
e700 flash ok but no power on | MTi-GsM | SYSOL Platform | 5 | 07-01-2005 19:58 |
