05-12-2004, 18:24 | #1 (permalink) |
Registered User Join Date: Jan 2002 Location: Sighetu Marmatiei,RO Age: 40
Member: 8527 Status: Offline Thanks Meter: 11 | E700 water damaged -- no display light Does anyone know what could be wrong or where can I find the circuit for backlight??? thanks anyway |
05-16-2004, 23:34 | #2 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Novi Sad, Serbia Age: 44
Member: 17193 Status: Offline Thanks Meter: 16 | You probably have a flat cable failure or some oxides left on pcb... Check capacitors near the connector hdc700 on the board, check if pin 46 gets appropriate voltage. Next, check r402 and c415 near u400. If everything is ok, try to bridge pin46 directly to +LED on the main screen. Post the results. |
1200 after water damage no light | mirfanmian | Nokia Hardware & Hardware Repair | 4 | 07-27-2011 15:41 |
nokia 6500 water damage , no display -solution pls | anand789 | Nokia Hardware & Hardware Repair | 1 | 03-12-2010 17:28 |
E700 no display light need solution | arushar1 | Samsung Hardware Repair | 2 | 01-21-2009 07:44 |
k700 water damaged,no back light,please | juliant_axl | Sony Ericsson Hardware Repair | 1 | 04-20-2007 11:37 |
K700 Water Damage No Keypad Light... | jameslym | Sony Ericsson Hardware Repair | 14 | 03-17-2007 14:38 |
