Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 01-19-2007, 11:26   #1 (permalink)
Member: 50261
E900 keypad hardware
Hi,
I have this E900 in which the top left button (menu) doesn`t work, i took the whole phone apart till i got to the keypad and can`t find anything wrong with it, maybe someone had a similar problem, please advise me something.
Old 01-26-2007, 08:44   #2 (permalink)
akkaamgopi's Avatar
Member: 247683
Thanks Meter: 49
e900
Originally Posted by Mantelis View Post
Hi,
Hi use this
Old 01-26-2007, 09:14   #3 (permalink)
Member: 50261
hi,
did you try this solution by yourself? can you point me to the thread where you found it?
thanks.
Old 01-30-2007, 17:36   #4 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 190
Solution not work.. any other solution ??? thnx
Old 01-30-2007, 17:54   #5 (permalink)
Member: 50261
I think the best solution is to buy a new keypad as it will save you a lot of time, in my case i think it was a chip on the keyboard flex that was faulty
Old 02-20-2007, 13:27   #6 (permalink)
Métal_gsm's Avatar
Member: 385254
Thanks Meter: 3
I've E900 with hanged KeyPad, Ive Trying to change The Slid but same problem, and I've Trying to Remove the Varistors in the picture but it same, any idea to fix this problem and the phone autopower by itself when i put Batt
if you have any shema ? Thinks
Old 05-01-2007, 17:07   #7 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
The solution of the sensitive keypad is the flex and just the flex but you must often close all the phone after changing the flex to see that it's ok. I had 3 mobile with this problem and i resolved it.
Bye
samsung e900 keypad kingmobiles01 Samsung Hardware Repair 4 10-05-2010 14:40
e900 keypad problem BALI2006 Samsung Hardware Repair 14 02-19-2010 18:18
Samsung e900 Keypad digital bounouar Samsung Hardware Repair 4 02-20-2008 14:23
E900 keypad membrain porn Wanted Products 0 03-25-2007 13:51
E900 keypad hardware Mantelis Trident/AGERE Platform 0 01-19-2007 10:21
Page generated in 0.17910 seconds with 10 queries
