06-21-2009, 13:42 | #4 (permalink) |
Junior Member Join Date: Jan 2009
Member: 942098 Status: Offline Thanks Meter: 1 | i encountered this problem when i changed a e900 display... however i don't guarantee this will work ... maybe just a few will be lucky .... Check where the flex ribbon is connected... make sure it's firmly inserted till the white little line on the ribbon is at the same level with the connector ... also check the connector for dust etc before you insert the ribbon . This worked for me but i'm not sure will work for everyone . |
Heeelp e900 LCD mix after flash help me | jawad8305 | Trident/AGERE Platform | 3 | 07-10-2011 22:33 |
Samsung E900 touchpad problem T_T | thaoanthony | Samsung Hardware Repair | 4 | 10-28-2010 15:19 |
E900 Lcd Key Lİght And Keypad | CEPHASTANESİ | Samsung Hardware Repair | 3 | 10-21-2007 09:49 |
Heeelp e900 LCD mix after flash help me | jawad8305 | UFS2 + UFS3-Tornadoflasher | 2 | 03-31-2007 14:46 |
e900 unlock problem | sewkar | UST Pro II | 12 | 08-11-2006 10:35 |
