05-05-2019, 18:57 | #1 (permalink) |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Offline Thanks Meter: 25,151 | Fix Not Registered On Network/No Service/Emergency calls only Make sure you are connected to Internet First Get Your Galaxy up and running, charged and ready Insert Working\ SIM card in phone Navigate to Settings of your Phone Scroll down to reach the extreme bottom Select Software Update Wait for it to reboot and complete the update Finished! Method 2 when you get phone for repair issue "not registered on network/No Service" problem .First Check these 1 Null IMEI Number/unknown 2 No Service 3 Unknown Baseband 4 Outdated Firmware 5 Radio is off 6 Blacklist in your Country You can check your IMEI number by dialling * # 0 6 # , you will see 0000 or nulled if it's corrupted. If you have an Unknown baseband then i suggest your to backup and restore your EFS Folder.This folder contains all the information about your phone. Simply go to settings , then go to about, then hit the update button.This will update you to an higher OS version If your radio is off , dial #*#4636#*# . Then click Phone Information.Run a quick Ping. After, Turn Radio OFF/ON
__________________ Just Follow the Rules and Be Polite Saying "thank you" can be hard. But it's so important. |
The Following 29 Users Say Thank You to mihut For This Useful Post: |
08-15-2023, 01:52 | #4 (permalink) |
Junior Member Join Date: Jan 2022 Location: Philippines Age: 45
Member: 3005567 Status: Offline Sonork: awindeyer1226 Thanks Meter: 0 | Thanks for this! I will definitely keep these in mind. Hopefully I get to fix the issue asap so my bcgameslots.com/id/ game session aren't disrupted. |
