Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 07-19-2018, 00:51   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
g900h back camera failed
already change camera
replace it above battery connecter but same
also reset but same
need solution ?
Old 07-20-2018, 23:54   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any solution ?
I replace ic 4 times
replace camera many times but same
also flash the phone but same
model is g900h
Old 07-22-2018, 17:58   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any idea masters.........?
Old 07-22-2018, 19:31   #4 (permalink)
Lesin KDR's Avatar
Member: 1988081
Sonork: 100.1627039
Thanks Meter: 63
hello dear ,
please check camara voltages and ic [attached manual]
https://www.4shared.com/rar/OHWxPxVSfi/SM-G900H.html
The Following User Says Thank You to Lesin KDR For This Useful Post:
Old 07-24-2018, 11:02   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
I follow this schematics
and apply this but still ba k camera failed
Old 07-24-2018, 11:25   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Old 07-26-2018, 02:19   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
is there any solution.......?
Old 07-30-2018, 02:10   #8 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
change camera
reball and replace ic
flash with same region but same
any tested solution ?
Old 08-02-2018, 19:16   #9 (permalink)
Member: 2669015
Sonork: jude101
Thanks Meter: 7
Do U check the number understand the camera
Old 08-02-2018, 20:05   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
yes I try many camera
and also from g900h but same
Old 08-03-2018, 03:53   #11 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
try check L809 maybe this item shorting ... if both rehot ic signal processor U806
Old 08-03-2018, 05:36   #12 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
l809 is show ground both sides
u806 change 3 times but same
Old 08-03-2018, 05:38   #13 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
should I remove L809 or what ?
Old 08-07-2018, 01:10   #14 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
kindly reply..........
this coil is short to ground
Old 08-08-2018, 06:28   #15 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
is there any solution or not ?
Page generated in 0.18283 seconds with 9 queries
