09-17-2017, 00:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | g900t no power and now charging problem problem : no power when connected to power supply : it takes auto amp without press power key action taken : replace max77804k but same finally remove l7011 and phone is on but charging problem on charging it show reverse charging % consuming when i put back l7011 phone again off without l7011 phone ok but charging problem any idea |
09-18-2017, 01:47 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
your current consumption is not showing right whether HH hit the water or fell check or replace C7016 and C7030 what if both of these items shorted | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
09-18-2017, 20:34 | #5 (permalink) | |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | Quote:
but when i remove l7011 set is working fine but charging consuming like i insert charger when battery is 5% after few minutes charging consumes and it show 0% | |
09-19-2017, 03:48 | #7 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | the problem is when I remove l7011 set power on if I put back l7011 set is not powering and take auto amp without pressing power key |
