11-01-2017, 20:15 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: romania, brasov
Member: 1439020 Status: Offline Thanks Meter: 16 | G920f display artefacts I separated the display from the glass and i get what you see in the picture; I also tested with a brand new display and i get the same result; I checked the display ways from the pictures in the solutions/ ways and they are ok; has anyone encountered this? what could i check more? @later edit: when i start the phone with the display connected it stays like this and shuts down; when i start it without the display connected it starts normally and boots because i can see the charging led lighting up blue and the board gets warm, indicating that it boots.... how to upload image on website |
11-14-2017, 12:53 | #5 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | check the working voltage of its lcd in C9017-C9021 and C9022 then rehot its display regulator at U9001 third of his fifth ic lcd checks on F9003-F9004-F9005-F9006 and F9007 if damaged (remove ic lcd emi filter) and jumper open the schematic of his diagram |
03-16-2018, 11:48 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: germany Age: 49
Member: 9584 Status: Offline Thanks Meter: 31 | i ve a s6 with dark Display. i changed the Display it work 2 minutes and it is dark again. the phone is on i see the lightzs on menü Buttons. can somebody help me |
