Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-23-2012, 11:18   #1 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
E2152 power off when charger connected.
Can any one help.E2152 turn off when charger connected (charger plugged to ac).if charger unplugged and i put charging jack than set remains on ,as soon i plug it to ac set goes off.
Old 04-23-2012, 11:33   #2 (permalink)
Member: 1733110
chek battery connector for karbon
Old 04-23-2012, 11:45   #3 (permalink)
Member: 1054255
Sonork: BISMILLAH.M.S.CENTER
Thanks Meter: 92
change ZD105-OK-----------THANKS
Old 04-26-2012, 19:35   #4 (permalink)
Member: 1691349
Thanks Meter: 22
DEAR MASTER
PLS CHANGE CHARGING SOCKET
Regards
Palmobile
@Service Team
Old 10-16-2013, 12:54   #5 (permalink)
Member: 308909
Thanks Meter: 3
meeter chek bsi pass ok but not working plz make jumper
Old 10-16-2013, 13:48   #6 (permalink)
Member: 1001290
Thanks Meter: 81
first chek off bsi middle track
Old 10-20-2013, 10:08   #7 (permalink)
samithashiva's Avatar
Member: 1356665
Sonork: 123
Thanks Meter: 31
chane first charger and then change connector
Old 10-30-2013, 10:23   #8 (permalink)
Member: 839615
Sonork: elpaso
Thanks Meter: 2
Change battery 100000000000000000 work
Old 12-25-2013, 11:54   #9 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 354
yes battery problem, battery's center point BSI stop working it may gives less -ve supply
Old 05-29-2016, 13:12   #10 (permalink)
Member: 1595101
Thanks Meter: 7
charging
no battery problem
Old 05-30-2016, 02:32   #11 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
Well in my opinion when you place the charging jackand plug in ac the set goes off that mean when you do that you have a short circuit it could be a ic's or capacitors
Well to be sure you need a power supply will connecting the charger on the same time and decrease or elevate the voltage of Power supply doesn't matter what matters is to read on power supply hight amperage without letting power supply restart
When you have this case you will start feeling ic's getting hot
Change it and check & test capacitors arround to see if broked or shorted and replace
You can as well change charger connectore
Only thanks botton
Old 03-15-2018, 16:04   #12 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 154
replace charging ic
take replacement from china phones
it is 6 pin ic pt116
Old 03-21-2018, 09:51   #13 (permalink)
Member: 2818409
how to find ways of any componen using avo in samsung core 2
method
how to find charging track
how to find data pins
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
How to use Nokia tool - with connection 6-7 pin or not?.. 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-20-2000 19:53
WE OFFER cables for connection cellular-phones to the computers GLEBUS Main Sales Section 0 06-04-2000 19:05
Nokia Datasuite Connection Failure Judesp Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-27-1999 09:36
For Jefferson -6110 goes off itself sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-19-1999 21:28
Page generated in 0.24363 seconds with 11 queries
