03-18-2013, 19:45 | #1 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1893457 Status: Offline Thanks Meter: 0 | Galaxy beam GT-i8530 lcd turned to black P.S : The phone works fine i can answer the calls ... etc bear with me my english is weak |
03-20-2013, 04:24 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,628 | Quote:
samsung gt-i8530 display solution first: check the voltage regulator ic lcd U503 work on C531 ... C532 and C533 check lcd power enable it in R514 if you still like the original rehot emi filter or replace lcd F503 F500 ... F504 .... F508 F509 and F510 ..... see the image below .... (the position of the component layout) only thank button | |
The Following 2 Users Say Thank You to d-Artigo For This Useful Post: |
10-25-2014, 17:01 | #3 (permalink) |
Freak Poster Join Date: Jul 2010 Location: sialkot pak ,saudiarabia Age: 39
Member: 1350832 Status: Offline Sonork: 100.1627308 Thanks Meter: 25 | i got a i8530 which trun off after running 10 minutes if u dont run any app song or call ir will not truin off what will be the prob its battery terminal is changed |
