09-13-2013, 21:32 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | 1-change battery 2-Rehot or replace power button key each leg for 20 second 3-Rehot your mobile board 4-check c416> 1.8v & c418 > 1.2v ??? If not change them 5-check c416> 1.8v & c418 > 1.2v ??? Change U406 6-check Osc400=32.768khz??? If not replace it or rehot it 7-check Osc400=32.768khz??? Replace or rehot U406 Don't forget to press thanks...... |
The Following 2 Users Say Thank You to habibboxes For This Useful Post: |
09-13-2013, 21:45 | #3 (permalink) | ||
Freak Poster Join Date: Jul 2002 Location: Croatia Age: 49
Member: 14004 Status: Offline Thanks Meter: 6 | I have several batteries, they are all OK Quote:
Probably one of the capacitors is shorted, i have allready lifted more than 20 of them, but didn't find the right one... | ||
09-14-2013, 00:19 | #4 (permalink) | |
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Quote:
in the schematic i did allready show you where the capacitore are....the red colore capacitore try to channge them if it didn't work try the second schematic the elements attached with booth capacitores before replacing u406 i'm waiting your result hope it will helps you bro | |
02-23-2014, 07:52 | #6 (permalink) |
Junior Member Join Date: Feb 2014 Age: 40
Member: 2127377 Status: Offline Thanks Meter: 4 | Did you try to use a hairdryer to heat your phone?my phone dropped in the water, i picked it up and use a hairdryer to heat it. And then put it under the sunshine for 3 hours, then it works! |
