Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 07-07-2012, 19:46   #1 (permalink)
Member: 1781653
Sonork: Peewee_02
Galaxy S3 no audio on call, pls need help
Hi guys i have a 5pcs of galaxy S3 with the same problem for all of the when you try or make a call there is no sound even if you will used the speaker headset there is no sound and when i end the call the signal bar becomes circle void but it will came back again the signal. i try to make a software and reheat the audio ic and it is the same still no sound on call....
Old 07-08-2012, 02:46   #2 (permalink)
roro_manool's Avatar
Member: 192974
hello man your solution is with me , it is me and only me who have that solution.
Old 07-10-2012, 17:12   #3 (permalink)
Member: 1781653
Sonork: Peewee_02
can u give me the solution for this problem please
Old 07-11-2012, 14:01   #4 (permalink)
BIGUNLOCKSERVER's Avatar
Member: 1542932
Sonork: 100.1621006
you have to shere the solution.
its forum, are u salling ur solution?
Old 07-19-2012, 07:29   #5 (permalink)
Member: 1781653
Sonork: Peewee_02
Do any one know how to fix this problem?
Old 07-19-2012, 08:31   #6 (permalink)
Member: 1434825
Update via Odin3 with the latest version and do a full master reset (*2767*3855#), if its a software issue it will be solved . Must use file of same region where the phone belongs to ,check it by dialing *#1234#. Eg. I9300jp*** jp for UAE region ,otherwise U may end up with update failure or damaged imei.. Gud luck br. Monish
Old 10-19-2012, 13:56   #7 (permalink)
Member: 1745234
Sonork: Sid.Kaz
somne plz hlp me i m new user:confu sed:
Old 11-07-2012, 11:41   #8 (permalink)
Moderator
Syed's Avatar
Member: 19979
i had a phone with similar problem and only a flash with latest firmware on ODIN fixed it..
WBR
Syed
Old 11-26-2012, 23:11   #9 (permalink)
Member: 545376
Hi! Change the audio ic and/or the audio codec ic!
do this:
mic working on dictaphone? (ok?) >>>
*#0*#
earp. working? (ok?) > speaker working? (ok?) > >>>
*#0283# earp. loopback working? > speaker loopback working?
no sound from earp + speaker? 70% audio ic
noise from earp and noise from seaker? 80% audio CODEC ic
when you will get 99% solution change the audio ic and the codec ic to!
Be carefull!
-When you soldering the audio CODEC ic to hot > you get camera problem
-When you soldering the aucio ic to hot > you get "phone unknown" ( IMEI: NULL/NULL)
Br: Zsolt
The Following User Says Thank You to 25011 For This Useful Post:
Old 11-27-2012, 17:45   #10 (permalink)
Member: 31604
Hi roro .. I have the same problem .. As this bro, but i am not sellin it to anyone .. Pls share it if u know
Old 11-27-2012, 20:40   #11 (permalink)
Member: 545376
XD XD XD no comment XD XD XD
why am i here? XD
Old 11-27-2012, 22:14   #12 (permalink)
Member: 545376
U604 - audio ic (proc.)
U605 - audio codec ic
Old 11-28-2012, 00:14   #13 (permalink)
Member: 192974
release for solution
for all guys the solution for S3 no sound under phone call I will release it tomorrow so all do not worry , I was in my holiday that is why I did not answer u all .
And u Mr BIGUNLOCKSERVER i do not have any paid solutions , so wait till tomorrow and u will get 1000000000000 % test solution and for free
The Following 3 Users Say Thank You to roro_manool For This Useful Post:
Old 11-28-2012, 15:26   #14 (permalink)
Member: 31604
will be waiting for ur solution
Old 11-29-2012, 15:14   #15 (permalink)
Member: 31604
still waiting pal , hope ur holidays were good
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.37301 seconds with 12 queries
