Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-22-2014, 12:28   #5296 (permalink)
Member: 2201845
i look for schema samsung s 5312 master
Old 11-24-2014, 15:01   #5297 (permalink)
Member: 1913362
samsung 3312 mobile shorting how can i repair plz help me
Old 12-04-2014, 06:36   #5298 (permalink)
Member: 861495
Thanks Meter: 52
samsung i9070 help wont turn on i press power and vibrate a little hekp me
Old 12-04-2014, 23:24   #5299 (permalink)
Member: 2060678
Thanks Meter: 5
hi i have samsung 9250 mobile i damage 1 sim point track .. how to repair track of 9250
Old 12-05-2014, 07:46   #5300 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
samsung gt-i9250 sim card ways
see image below
only thank button
Old 12-05-2014, 16:22   #5301 (permalink)
drbilal's Avatar
Member: 213808
Sonork: 100.1615441
Thanks Meter: 126
need s7582 lcd solution
need s7582 lcd solution or schmetic..................
Old 12-09-2014, 06:16   #5302 (permalink)
fum
Member: 2263030
Sonork: 100.1659104
Thanks Meter: 23
Originally Posted by d-Artigo View Post
samsung gt-b5330 power on off ways
try trick image below :
only thank button
bro i need sony st 25i usb ways....most important d+ full way
thx
Old 12-11-2014, 08:40   #5303 (permalink)
Member: 2308703
S 4 mini 9190 insert sim in sim 0ne can any one help me
Old 12-11-2014, 20:42   #5304 (permalink)
Member: 1631147
Thanks Meter: 116
B 5330 try this but signal is full and insert sim
Red one is broken
Old 12-13-2014, 04:39   #5305 (permalink)
Member: 2231667
Sonork: Www.sonork.com
samsung gt i9082 automatic off its not start all line is ok
Old 12-18-2014, 17:52   #5306 (permalink)
Member: 1417396
Thanks Meter: 16
plz need g350 charge way
Old 12-22-2014, 06:55   #5307 (permalink)
Member: 1670212
Sonork: K.C.Behera
Thanks Meter: 5
Dear,
Sir samsung s5620 sim track ways solution
Old 12-22-2014, 08:03   #5308 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
Originally Posted by K.C.Behera View Post
Dear,
Old 12-25-2014, 15:32   #5309 (permalink)
Member: 2257879
samsung s3500i shorting problem solution
Old 12-29-2014, 09:33   #5310 (permalink)
Member: 1501934
HERE YOU CAN FIND SOLUTION FOR SM-G850 NO POWER PROBLEM
No Power
Step Check point Result value Defect point
1 Confirm the defect symptom - -
2 Check the battery terminal visually
Damaged Battery terminal
Normal Go to the step 3
3 Check the PBA current with a power supply
(power supply voltage : 3.8 ~ 4.0V)
High current (over than 3A or
under 50mA) Battery path circuit short
Normal current (Current
change) Display or Power key
Other current case (0mA or
other) Go to the next step
4 Check the Vbatt(+point) of IF PMIC output
Same as power supply voltage Go to the next step
If not the correct value IF PMIC (U701)
5 Check the voltage of XNRSTOUT test point
(Typical 1.8V fixed)
Voltage level of T/P = 1.8V Go to the next step
If not the correct value AP PMIC (U702)
6 Check the frequency of Main clock source
OSC500 (R631)
R631 = freq 24MHz signal Go to the next step
If not the correct value X-tal part (OSC600)
7 Check the voltage of eMMC memory
C694 = 2.9V
R653 = 1.8V Other part initial fail
If not the correct value eMMC Power(U600)
***All Samsung Hardware Solution*** bunty2008 Samsung Hardware Repair 33 01-14-2020 14:10
All Samsung Hardware Solution bsat Samsung Hardware Repair 25 10-13-2018 12:43
Page generated in 0.30940 seconds with 11 queries
