12-29-2014, 09:33 | #5310 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1501934 Status: Offline Thanks Meter: 0 | HERE YOU CAN FIND SOLUTION FOR SM-G850 NO POWER PROBLEM No Power Step Check point Result value Defect point 1 Confirm the defect symptom - - 2 Check the battery terminal visually Damaged Battery terminal Normal Go to the step 3 3 Check the PBA current with a power supply (power supply voltage : 3.8 ~ 4.0V) High current (over than 3A or under 50mA) Battery path circuit short Normal current (Current change) Display or Power key Other current case (0mA or other) Go to the next step 4 Check the Vbatt(+point) of IF PMIC output Same as power supply voltage Go to the next step If not the correct value IF PMIC (U701) 5 Check the voltage of XNRSTOUT test point (Typical 1.8V fixed) Voltage level of T/P = 1.8V Go to the next step If not the correct value AP PMIC (U702) 6 Check the frequency of Main clock source OSC500 (R631) R631 = freq 24MHz signal Go to the next step If not the correct value X-tal part (OSC600) 7 Check the voltage of eMMC memory C694 = 2.9V R653 = 1.8V Other part initial fail If not the correct value eMMC Power(U600) |
***All Samsung Hardware Solution*** | bunty2008 | Samsung Hardware Repair | 33 | 01-14-2020 14:10 |
All Samsung Hardware Solution | bsat | Samsung Hardware Repair | 25 | 10-13-2018 12:43 |
