Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 06-07-2005, 17:09   #391 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
@ tariq
Originally Posted by taariqjee
dear
friends i have samsung c100 and i flash it with ufs3 tonado box
after flashing mobile is okey but displaying no signal
i am too much worried that what should do
any body please tell me what is the solution
regadrs
tariq
Hi tariq,
Don't worry!!!.
Use A300 Cable (modified) and download C100 full E2p. Everything will be OK.
If u need I will send this files for u.
(Don't use UFS).
B.R
Vinh Hai
Old 06-07-2005, 20:44   #392 (permalink)
Member: 84028
I got a X430, new only 2 days used, problem is suddenly the ring tones began to play faster and sounds are not as same as it were before. I flashed it 3 times with UFS3. Result 0. Please help me.
Old 06-07-2005, 20:49   #393 (permalink)
Member: 84028
Red face Nokia 2600/3100 no light at dispay and keyboard
I got Nokia 2600 and 3100, both works fine but no light at display and key pads. Kepads leads are ok. I flashed it with UFS 3 , no result. Pls provide me solution.
Old 06-07-2005, 23:38   #394 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
Originally Posted by gsmkonnexion
Hi, i have an R220 that charges itself, even when not connected to charger. Got any repair solution for me .
Clean motherboard & Connector
If problem not solved, change LTRG first then P200
100%%%%
Old 06-08-2005, 00:33   #395 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
dear
regadrs
tariq
Sol.1:
- use UST ...set comport and phone model!!
for C100 u'll have "repair SW problem" button activated !!!!
connect phone in test mode then click on "repair SW problem" !!
Or try RESET MMI with UFS
Sol.2:
- TRy these
1. Rewrite imei
not O.K.
2. Remove the 2 varistor behind the LCD
Sol.3:
- use C100 Full flasher with e2p (Flash file=16MB), at DOS mode using 98se
Link: http://www.restech.pl/upload/index.p...=SAMSUNG/FLASH
Old 06-08-2005, 07:21   #396 (permalink)
Member: 143801
if anybody can send me samsung X-120 pc software..... pls................
this my e-mail...
[email protected]
Old 06-08-2005, 10:54   #397 (permalink)
Member: 151459
single you know to copier-coller EMINEMGSM for hardware
Old 06-08-2005, 10:56   #398 (permalink)
Member: 151459
Old 06-08-2005, 23:56   #399 (permalink)
Member: 5292
Thanks Meter: 5
Change cristal neiar to power IC
Old 06-09-2005, 14:01   #400 (permalink)
Member: 127617
Unhappy X460 keypad not working
I have X460 keypads do not work ,need solution .Please.
Old 06-09-2005, 20:39   #401 (permalink)
Member: 127428
Thanks Meter: 51
e700 hanging up
pls. kindly help , what shoud be the cause of sam. e700 that hang up when
sending call?
Old 06-10-2005, 03:57   #402 (permalink)
Member: 151659
am missing since all this days
please i just need your help by send any solution to my email box bicos i have miss a lot please my mail is [email protected] :
Old 06-10-2005, 04:37   #403 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
Originally Posted by Burim
Did somebody find the solution for this problem I have 2 phones with same problem.
Thanks
WBR
do reset settings in phone menu and set any wallpaper now switch it off and put oncharger for 10 minutes after that dont touch the phone for 30 minutes atleast try and post results
Old 06-10-2005, 04:38   #404 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
Originally Posted by s1emens
I have V200 can show charging but it hard to power up, sometimes when we press ON buton it can turn on. I think there are a problem with ON button. Could someone help?
BR,
s1emens
100% solution---------- reflow or change power ic tested in many sets
Old 06-10-2005, 04:39   #405 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
Originally Posted by JoAoOpAuLo
S300 dead after Nbox + A300 cable
Would anybody have a solution for that problem?
Thanks in advance!
dismantle and short backup batt points for awhile thats it
***All Samsung Hardware Solution*** bunty2008 Samsung Hardware Repair 33 01-14-2020 14:10
All Samsung Hardware Solution bsat Samsung Hardware Repair 25 10-13-2018 12:43
Page generated in 0.25954 seconds with 10 queries
